Car problems once again - Car Audio Classifieds!
Old 01-11-2010, 08:10 PM
Bushj311's Avatar
0/11 sssss5532
Feedback Score: 45 reviews
Default Car problems once again
Well driving today i hit the gas and the car does not want to move. It like stutters for over 15 seconds and then all of a sudden it will seem as if i crushed the gas pedal with my foot.
Then going up this hill it did it again and i heard a few poof sounds from under the hood and the car eventually started going again.
Any idea on this problem? Could it be related to the check engine light that the guy reset?
Old 01-12-2010, 02:36 PM
Bushj311's Avatar
0/11 sssss5532
Well today the car did it again. only this time it was way longer and almost every time i hit the gas. Then finally coming up the hill to my house it completely turned off. Now it will not turn over at all. check engine light came back on too. and then the check gauges
Old 01-12-2010, 02:38 PM
jwesenick79's Avatar
not loud yet
0/11 ssssss882
have you tried putting a scanner on it and seeing what/if any codes came up?
149.4 dB and climbing....
18" Solo-X, Shok Industries 3.5k and two 100.4s, 250 amp Mechman Alt, 4 runs shok competition cable. TEAM SHOK - WI
Old 01-12-2010, 02:41 PM
Real Talk
0/11 ssssss291
Loose battery connection? Bad alt? misfire? idk
Old 01-12-2010, 02:43 PM
Bushj311's Avatar
0/11 sssss5532
alt is good. batts are good. all connections good.
It does not run to take it to get codes ran
Old 01-12-2010, 02:44 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Did you ever figure out the problem in the first place? And what codes it had then?
My Car, My Ears.
0/11 sssss4714
What year is your blazer?? And you might either have a weak fuel pump, plugged fuel filter, or your spider is bad!!
TEAM GORILLA
TEAM GHOST MOB
2007 Ford F150
1995 T-Bird P.I. 4.6L 312rwhp-Comp car,work car
Trunk Car class for 2011 MidwestSPL division!!
Old 01-12-2010, 02:47 PM
Bushj311's Avatar
0/11 sssss5532
1997 s 10 blazer
Never found out the first problem
Old 01-12-2010, 02:49 PM
0/11 sssss4714
It might be your spider, which is your fuel injector rails, they look like spider legs, up under the intake, but could be something simpler, I just know that the spiders are a common problem, and Ive changed a few!
TEAM GORILLA
TEAM GHOST MOB
2007 Ford F150
Old 01-12-2010, 02:54 PM
Bushj311's Avatar
0/11 sssss5532
I will try to look into that. I will end up just towing ti to the shop. my car is 2 blocks from my house. i cant walk tools down and back all day lol
Having some problems, need help. RE_Gawker General Car Audio Discussion & Questions 9 09-14-2009 05:45 PM
I have some problems... RE_XXX Off Topic Chat 58 09-04-2009 01:12 AM
Problems with new amp. worstenemy453 General Car Audio Discussion & Questions 28 06-17-2009 03:21 PM
