Mechanics, come hither! - Car Audio Classifieds!
Old 01-13-2010, 04:53 PM
0/11 ssssss224
Exclamation Mechanics, come hither!
Okay, got a slight problem here guys. My 2002 blazer is seeming to overheat and lifted the hood up, and steam rolls everywhere! I dont see where it could have came out of the radiator. All hoses seem to be in good shape, but water/antifreeze is all over the engine compartment.
Any ideas as to whats going on?!
Refs:
Old 01-13-2010, 04:54 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
Feedback Score: 41 reviews
is there preassue in the coolant lines? if you squeeze the upper radiator hose youll hear air coming out of see coolnt come from a hole. if the hoses are fine start it up. youll see where its coming from.
Old 01-13-2010, 05:05 PM
0/11 ssssss224
Okay, I squeezed the top right hand hose and i hear the air, I then squeezed the bottom hose and you could hear it making a noise in the water, like blowing bubbles in your soda.
started it up, and didnt see anything, let it run for bout 5 minutes and no fresh water spots on the ground..
Refs:
Old 01-13-2010, 05:08 PM
sound_around's Avatar
0/11 sssss9691
A common problem on Chevys is on the intake where a metal coolant line connects to it.
Old 01-13-2010, 05:09 PM
0/11 ssssss224
this is what I was thinking earlier, I forgot to check it out. I got sidetracked on the phone with a buddy about this delima. I am gonna go check this out..
Refs:
Old 01-13-2010, 06:26 PM
0/11 sssss9691
What did ya find?
Old 01-13-2010, 06:30 PM
0/11 ssssss224
Okay, I let it heat up to normal temp..NOTHING! No leaks, no noises no nothing...
Refs:
Old 01-13-2010, 06:39 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
let it get cold. then pop the cap and check the coolant. make sure its still green. if it is let it run in the driveway until it gets hot. make sure it comes up to operating temp liek 180-200 on the temp guage.
if the thermostat went and got stuck closed itll overheat. and send everything out the overflow.
Old 01-13-2010, 06:47 PM
may03LT's Avatar
0/11 sssssss70
Did you fill up the radiator prior to doing this?
Looking for leaks by relying on system pressure is too slow, I use a cooling system pressure tester like this one
2003 Trailblazer LT
Old 01-13-2010, 07:02 PM
0/11 ssssss224
Im going to go buy me a pressure tester tomorrow so that I will have it in the future. Im hoping the tstat is fuked up already, its not even a yr old =\
Refs:
Popular mechanics + challenger + hybrid???? F3M4 General Automotive Chat 5 08-14-2009 06:06 PM
