Carburated Turbo? - Car Audio Classifieds!
Old 01-26-2010, 01:53 PM
Biggy's Avatar
Loyal Member
0/11 sssss2240
Default Carburated Turbo?
Hey,
this is something i'm thinking about since some time.
since we have the scrapping premium (sp?) since beginning 2009, we have tons of good engiones / parts on a junkyard nearby and i realy want to do a Engine Project, first i thought i could get the 1.8 20V Turbo out of the Golf, rebuild it and make it more powerful, but that just looks too easy.
Now i'm thinking about using a 1.9L Turbo Diesel Bottom End with a 8valve Head and Turbo Diesel Manifold.
Since i'm realy into Old School i would like to use a Carburator, i know it is possible, but i'm not quite sure how.
Any of you guys got knowledge about a Turboed Carburator Engine? Does it sit before or behind the Turbo? are those special units or just diffrent injectors with a pressure regulated fuelpump?
i'm not lookin to build a high power engine, i just want to do something a bit special, not like everyone else slapping a big turbo kit ontop of a stock motor.
If you hear any Clipping, it may be your Ears or the Coils hitting the End Stop
Sundown Audio Germany
Hey, what can I say? I love me some poonanner. Even if I have to hit them with a door and handcuff to the chair.
Old 01-26-2010, 02:28 PM
0/11 sssss2351
Originally Posted by Biggy View Post
Hey,
uh... behind the turbo? I think you should read up a bit before you dive into a project like this. And it is possible to have a turbocharged carbed motor. It's called a blow thru carburetor google it.
Here ya go even helped take some of the work load off for ya... blow through carburetor - Yahoo! Search Results
4 15" Audiopulse Revos
2 SAZ3k's strapped @ 1 ohm
7 stinger Spv70 batts
1 Iraggi 300 amp alt
Old 01-26-2010, 02:39 PM
Biggy's Avatar
Loyal Member
0/11 sssss2240
i know it's possible
and i know there's a suck-though and a blow through type, that's what i meant with before/behind the turbo, just didn't knew the english word for it
I'm more interested in what kind of carbs to use or how to modify stock carbs
Old 01-26-2010, 02:43 PM
98AckCL23's Avatar
0/11 sssss9929
Turbo and ITB's would be sexier...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 01-26-2010, 02:44 PM
0/11 sssss2351
I'd definetly run blow thru. If you use this suck through your talking about look how far the fuel has to travel after the carb to get into the combustion chamber. You'll get a weird idle a never get consistent tuning with fuel pooling up in the "Intake".
Old 01-26-2010, 02:50 PM
Biggy's Avatar
Loyal Member
0/11 sssss2240
yea, but way more expensive and harder to do too, ITB would need a stand alone or atleast a piggyback management system
let alone that ITB's are not like carbs just laying arround on a junkyard
Old 01-26-2010, 02:51 PM
Biggy's Avatar
Loyal Member
0/11 sssss2240
that's what i thought too, but there i wouldn't have the problem with the carb being under pressure..
Old 01-26-2010, 02:52 PM
ghostmechanic's Avatar
0/11 sssss1193
Feedback Score: 36 reviews
That's kind of rude & I think you need to do some research of your own & not just rely on what you read on the internet before you try to give out "advice".
Carburetors suck! But you can do either with a turbo charger. If you do it with the carb after the turbo (basically adding the turbo to the engine) you are very limited by the amount of boost you can use. Somewhere around 6 psi. If done before the turbo you can get by with more boost but plumbing becomes way more complicated. And there's another drawback but I forget what lol.
Either way you need an FMU or something to get more fuel when the turbo boosts. I had plans at one time to put dual turbos on a V8 Mustang back in the early 90s but I ended up scrapping the project. So I haven't actually done either but I've owned many turbo charged cars. They were just all fuel injected. It's been many years since I did all the research to add the turbos to that carbureted engine so I'm sure I've forgotten most of what needs to be done.
u need a flux capacitor to do that bro
i swear i thought you guys were serious until i googled flux capacitor
Old 01-26-2010, 02:59 PM
0/11 sssss2351
LOL limted to 6 psi? Alright mister ghost mechanic.
With anything more than 6psi your advised to run a bypass or blow off valve. you can run more than 6psi on a blow thru set up.
Old 01-26-2010, 03:19 PM
0/11 sssss2351
Your best bet is to do your own research and decide what you really want to do after that.
here's a turbo related forum. http://www.theturboforums.com/
GL
Tn craigslist dsm turbo $1000 sound_around Bargain Bin 6 08-23-2009 03:19 AM
Turbo question 92K1500 General Automotive Chat 20 02-15-2009 09:33 AM
awsome homemade turbo korey_hofer Off Topic Chat 6 12-29-2008 11:01 PM
My 97 supra racing a 1990 mazda RX7 turbo flores210 Member Rides & System Pictures 9 11-05-2008 02:06 PM
