alternator in the trunk - Car Audio Classifieds!
Old 04-22-2010, 05:23 AM
0/11 ssssss256
Default alternator in the trunk
Ok, I'm building my f...k around car, 1974 toyota celica, I'm swapping a 13b turbo II s5 engine, car is 2500 hundred pounds, engine has 200 hp stock, u do the math !
So as we stand right now engine is mounted, engine swap came with wiring and computer, but I also got a microtech lt10 for it!, well plans change, is not a daily driver so just for the cool factor I ripped the electrical out and I'm working on a blown thru turbo system with a marine holley carb! I love the old school look, I'm puertorican, got no choice! Hahahahaha!
I'm replacing the water pump with an electrical remote mount pump, so the only thing being driven by the crank is my alternator. Now just for the naked look and weight distribution, I want to eliminate the alternator and place it in the trunk running of a 12v motor, I have the idea but I'm not sure of the electric motor I would need, that's where all of u electrical geniuses come in play!
I need a motor that would at lease run at 3000 rpm, be power by a 12v bat in the trunk, heavy duty. Affortable!
Any ideas, suggestions or experience let me know!
(Once the alternator is gone, I would have space for the eaton m90 on top of the engine, can u say twincharge baby!)
Old 04-22-2010, 05:29 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Um, the elec motor doesn't have to spin 3000rpm....
You use gear ratios for that.
I don't know how fast the alt has to spin to put out it's max amperage so I can't tell you what gear ratio to use.
And you will need a good heavy duty motor if you plan on putting any kind of strain on the alt because they can get pretty difficult to turn under high load.
Team CACO Team SHOK
Supporting Member
Old 04-22-2010, 05:42 AM
0/11 ssssss256
Nice, good info. I'm at work right now, as soon as I get home I get the specs and some pics, for viewing pleasure!
you can't run the alt off of an electric motor and create enough power to turn it properly other wise people would just use generators to power their house and then just plug the generator into the wall and free electricity
Old 04-22-2010, 06:29 AM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
are you serious?
you want to run an alternator off an electric motor and expect the combo to actually create energy? Something in the system would have to be over 100% efficient to create ANY electricity..
Old 04-22-2010, 06:40 AM
0/11 ssssss284
that wont work
Old 04-22-2010, 06:44 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
If the alt puts out more than the motor draws it'd produce power...........
If it takes 30A to spin the alt, and the alt can put out 120A then you have 90A to play with.
It's not the best way, but I still think it could work.
Team CACO Team SHOK
Supporting Member
Old 04-22-2010, 06:50 AM
0/11 sssss6061
Lmao this is hilarious. It takes energy to make energy. You can't just run little generators to spin bigger generators lol. That would definitely solve the worlds energy problems if you could though.... lmao
Old 04-22-2010, 06:55 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Well, think about it. The alt is charging your battery, the motor spinning it would just be a draw like turning your headlights.
2x 35W lights is 6A worth of constant draw on 12v.
My 2x 100W KC lights were 16-17A of draw.
So if the motor spinning the alt only drew 20A it'd be no different than me running my KC lights.
Team CACO Team SHOK
Supporting Member
Old 04-22-2010, 07:01 AM
0/11 sssss6061
nvm. I read it wrong. Sleep deprived.
backseat vs. trunk sheldonfromltown General Car Audio Discussion & Questions 38 02-20-2010 08:18 PM
Sagging trunk hornedfrog1985 General Car Audio Discussion & Questions 15 02-05-2010 02:00 PM
150db out of a trunk Buddah_iii General Automotive Chat 8 10-26-2009 11:56 PM
Trunk gets wet gbo559 Off Topic Chat 11 09-24-2009 12:13 PM
18 in a Trunk MaTT6387 General Car Audio Discussion & Questions 60 04-14-2009 12:59 PM
