Car is acting up Help Please! - Car Audio Classifieds!
Old 05-16-2010, 06:03 PM
aturcotte127317's Avatar
Veteran Member
0/11 sssss3613
Default Car is acting up Help Please!
So today i turn on my car and my voltage read 15.2
The my SRS light was on (im guessing that mean service required soon )
Also my Brake idicator light on my dash is on
Also my battery indicator light is on
I disconnected my upgraded alt wire and now im sitting at 14.8-14.9 but still thats ALOT higher then my usual 14.1ish (i kill my alt )
Any input as to what to do or what may be wrong would be greatly appreciated. I'm no mechanic so i have nooo idea
147.5 sealed on dash
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 05-16-2010, 06:04 PM
did you replace the original alt wiring? because you are supposed to leave that
Old 05-16-2010, 06:05 PM
0/11 ssssss103
My voltage rests at 15 when no music is playing. 14 when full tilt. I have never had any problems. But if the battery light is on, check all connections. Are your wires soldered? You are supposed to leave all stock wires and just add over top them.
Old 05-16-2010, 06:12 PM
BlackWaterOp's Avatar
Super Moderators
0/11 sssss4420
Feedback Score: 35 reviews
SRS is an airbag I believe.
eBay (douglas.leejr) 666+ Feedback 100% Positive
PayPal Premier Verified Since 2004 (
E-thug:
If u dont wanna be here i can make sure u get the banhamma
lets keep it as simple as that.
TEAMLOWPOUNDERS
0/11 sssss3564
srs is the air bag system...and my friends car was doing that too we figured out that the ground wasent string enought so he had to connect it better..but this might no be the case...might have something in your factory wire messed up idk....
CAR: 2008 f250 6fo
BATTS: 2 100ah
SUBS: 1 Hybrid 18
AMP: 1 Sundown SAZ3000s
Old 05-16-2010, 06:25 PM
Veteran Member
0/11 sssss3613
Yep all of the original wiring is still there.... Do you think this could be casued by maybe the +on the alt having more current flow then the ground?
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 05-16-2010, 06:37 PM
lileddie1127's Avatar
0/11 sssss1225
What kind of alt? My mechman was causing voltage spikes so I spliced my sensor wire on the mm alt (yellow wire) and crimped a ring terminal on the end and attached it to my pos post on the alt itself....voltage spike problem went away.
6th order coming soon!
Team Juggernauts
Old 05-16-2010, 06:38 PM
Veteran Member
0/11 sssss3613
I am still rockin the stock alt
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 05-16-2010, 06:40 PM
TEAMLOWPOUNDERS
0/11 sssss3564
with my stock alt i dont have problems like yours its 120 amp and i sit at 14.9 volts 15.0 when its cold??
CAR: 2008 f250 6fo
BATTS: 2 100ah
SUBS: 1 Hybrid 18
Old 05-16-2010, 06:41 PM
Veteran Member
0/11 sssss3613
Hmmmmm maybe it has nothingt o do with my alt then.. I might end up having to just take it to a shop :/
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Fedex is acting gbo559 Off Topic Chat 6 08-27-2009 03:44 PM
