Any Ford people with any engine knowledge? - Car Audio Classifieds!
Old 12-11-2008, 09:49 PM
0/11 sssss4511
Feedback Score: 52 reviews
Default Any Ford people with any engine knowledge?
i have a 351 windsor that i was going to sell but it doesnt seem worth it to let go of it. engine is brand new.
im looking to start piecing it together real soon. this is going to be a slow build. what i plan on getting 1st is edelbrock 202 cylinder heads. is there anything else out there around $600 that are better than these. also any good places that you reccomend to buy from?
would it be better to bore(sp?) it out to a 427? has crossed my mind but i honestly dont see it too much better. any imput and reccomendations on which parts to go with will be gladly taken. oh and i plan on putting a 6 speed tranny too.
its not always about cone area people, dont forget to determine the displacement of comparing multiple sub setups.
sd x xmax=total displacement
Old 12-14-2008, 04:29 PM
0/11 sssss3181
Feedback Score: 23 reviews
make sure you get the right firing order when you get to that point. they changed the 302 a few years before... i assume they probably changed the 351 as well. take a look at JEGS they have a lot of parts numbers. then go online type in the part number and all that jazz
Old 12-14-2008, 05:45 PM
0/11 sssss3638
i wouldnt bore it our that much, i bored the 351 cleveland out .40 over
Old 12-14-2008, 05:47 PM
Prohibited Sellers/Buyers
0/11 sssss6709
Feedback Score: 17 reviews
Look into DART heads.
Old 12-14-2008, 05:50 PM
0/11 sssss3638
and thats where i stopped reading
Old 12-15-2008, 09:20 PM
dart heads for 600 huh
any way cheep way would be getting some 2 barrel Cleavland heads and have them ported as the chambers are small and are better than the 4 barrel
Old 12-15-2008, 09:42 PM
andrew198501's Avatar
0/11 ssssss873
Dart has awesome heads!!!! I would say dont bore it over .30 that way if it blows it can be rebuilt IMO.......Summit is awesome i have been ordering from them for 5+ years now and have not had any problems yet....Thank god LOL
Click here^^^^^^^^
Old 12-15-2008, 10:08 PM
DEAFWISH's Avatar
1 + 1 = 3?
0/11 sssss1018
Afr 185 heads work great on big cube Windsors for street/strip.
Old 12-15-2008, 10:31 PM
No, I'm not dead
0/11 sssss8128
You couldn't bore it to 427 cubes without having the cylinders bored completely out of the block and sleeving it. To hit 427 cubes easily you'd have to bore and stroke the block which means you'll need a crank, possibly rods and definitely pistons/rings. Myself I'd just get good aluminum heads and a cam with a 3000RPM to 6500RPM powerband and call it good.
If you go hydraulic lifter cam, spend the extra bucks and get Rhodes variable lifters. You'll gain back some low end torque lost by the bigger cam and have a much smoother idle.
Old 12-15-2008, 10:38 PM
DEAFWISH's Avatar
1 + 1 = 3?
0/11 sssss1018
408 is a good street Windsor, Eagle sells a drop in crank/rod/piston kit for this displacement.
[BASIC] Engine whine and Ground Loop Fixes danteBirosel Tutorials & Quick References 0 11-12-2008 02:05 PM
[BASIC] Engine whine and ground loop fixes danteBirosel Tutorials & Quick References 0 11-12-2008 01:38 PM
Mazda developing vehicles for people with special needs Patrick Simmons General Automotive Chat 7 11-07-2008 10:11 PM
Why some people just shouldn't be mods bumpin buick Off Topic Chat 54 11-06-2008 02:02 PM
How many people can you name... Patrick Simmons Off Topic Chat 4 09-11-2008 04:55 PM
