would this cause that ? - Car Audio Classifieds!
Old 05-27-2010, 06:28 PM
CLNFREAK's Avatar
0/11 sssss1788
Feedback Score: 23 reviews
Default would this cause that ?
my car seems to be getting really hot lately. its a 06 impala
i think that my alt is on it way out, (winny) voltage is still good tho.
question is could a bad alt cause my car to over heat ?
what ya think ? I dont have the time to tear in to it and its pouring out
got a spare alt but woundering if I should bother trying it
let me know what ya think
MAY 8 2009 ask me about that day !!!!
SUBS (2) 12" DC LVL 5
SUB AMP 1100.1
MIDS AND HIGHS AMPS 2 EXL 400.4
BATTS NSB group 31, XS power d3400
SINGER ALT 350 AMP
TEAM DC
DCSOUNDLAB.COM
SINGERALTERNATORS.COM
Old 05-27-2010, 06:49 PM
0/11 sssss1560
mmmmm not if your voltage is good keeping fans running. what is it that is "hot" engine bay inside coolant? use more details!!!!!!
Old 05-27-2010, 07:02 PM
orangelss's Avatar
I Role Old School
0/11 sssss2112
You might be getting alot of drag out of the alt that is causing the motor to have to work harder to keep RPMs up?
My Allis has a big ass!!
Old 05-27-2010, 07:16 PM
30Hz
0/11 sssss6601
Feedback Score: 47 reviews
whens the last time u checked the coolant or changed it?
i put in a lower temp T-stat in my truck to bring the temp down. another thing try spraying water thru the radiator it could be cloggin up with dif elements.
i dont thing a baring going out or just a bad alt. will drag yer motor hard enuff to rise yer temp that noticeable on the gauge
Old 05-27-2010, 07:29 PM
orangelss's Avatar
I Role Old School
0/11 sssss2112
Not to argue, but you would be suprised. Might try running you car for a bit and putting you hand on/near the alt to see if its getting hot faster than the motor. They will get warm but you should always be able to put a hand on them. Just don't get a finger or something cought in the belt. That might ruin your day.
Old 05-27-2010, 07:33 PM
CLNFREAK's Avatar
0/11 sssss1788
the overflow is empty... just checked it.
I hope its not a freakin head gasket or something like that.... hmmm ?
the "hot" is when it pegs the gauge and the HUD says overheat turm off motor.
guess I will look in to a coolant change, I got a warrenty on the motor till 100,000 (cars got 55k now) so if its a engine issue its covered, I just dont want them sayin "its cause of your sterreo..... bla bla bla "
at 55k..... guess it could use a coolent change... but I wouldnt think so
and it idles fine so that is why i think that the alt couldnt be it..... cause if it was really bad to draw the motor down I would think it would stall at idle
SUB AMP 1100.1
SINGER ALT 350 AMP
TEAM DC
DCSOUNDLAB.COM
Old 05-27-2010, 07:36 PM
orangelss's Avatar
I Role Old School
0/11 sssss2112
Oh my thats a little warmer than I was thinking!! Hope the motors ok. Maybe the water pump or something smaller like that has gone out. Hoping for yeah!!
Old 05-27-2010, 07:40 PM
CLNFREAK's Avatar
0/11 sssss1788
ye I just noticed it the other day, my drive to work is a min and the fan started to come on.... guess time to get some warrenty work done.....
SUB AMP 1100.1
SINGER ALT 350 AMP
TEAM DC
DCSOUNDLAB.COM
Old 05-27-2010, 08:08 PM
0/11 ssssss216
how about your drive belt, have you changed it out? might be slipping causing some issues and making things run hot. i have an 07 impala and have 34000 miles on mine, just installed my new ho alt about two weeks ago and my belt while i was at it. it's a good thing i did my old belt was trashed as a i took the belt off i noticed that the old belt was split down the center.big difference overall with the way the car is running since i changed the belt out.
Old 05-27-2010, 08:17 PM
skinnyg's Avatar
0/11 ssssss828
if you hear a squeak noise it could just be a belt or tensioner, maybe water pump but im not sure if it runs off of the timing belt or drive belts on that car
