car starting problem - Car Audio Classifieds!
Old 06-05-2010, 11:14 PM
0/11 sssss1143
Default car starting problem
so last couple days. i go to start my car and it wont fire up on the first turn of the key. it wants to start but don't. so i turn the key off and then try again and it fires right up.......any ideas what it could be? and it only does it after the car sitting for a while. its an 04 grand prix.
Old 06-05-2010, 11:16 PM
0/11 sssss1435
fuel injection? try stepping on gas before turning the key
Old 06-05-2010, 11:20 PM
thegreatestpenn's Avatar
lazy genius
0/11 sssss2592
Feedback Score: 25 reviews
could be the starter. could be fuel injector. could be the batt was sitting at low voltage.
MECA spl and sql judge
termleezy fo-sheezy
Old 06-05-2010, 11:22 PM
Dunbar91's Avatar
0/11 sssss6816
Feedback Score: 51 reviews
x2 on the starter and check ur batt terminals...if theyre fuzzy and have the fuzzy looking green/gray...clean em off.
Old 06-05-2010, 11:26 PM
0/11 sssss1560
Fuel pump/filter
if ur filters old change it out
Old 06-05-2010, 11:29 PM
sound_around's Avatar
0/11 sssss9691
Low fuel pressure from either a partially clogged filter or a weak fuel pump and/or clogged injectors.From what I gather it is taking 2 key cycles to hot charge the fuel system with fuel..
Old 06-06-2010, 07:49 AM
0/11 sssss1143
alright thanks for the suggestions guys. i changed the fuel filter, and plugs and wires. i needed to do the plugs and wires anyways. but i will run some fuel injector cleaner when i fill my tank today, and see what happens.
Old 06-06-2010, 08:26 AM
0/11 ssss31258
Default my suggestions and liklihood
[25% likelihood]tune up
tune up on a 99 granprix = spark plugs and wires, oil change = $100 in parts and materials.
I list this first because it is the cheapest fix and can be done by most people.
[50% likelihood]fuel pump = $250ish plus install.
If it is your fuelpump, the reason you have to turn the engine over more than once is because you are having to prime the system because it can supply enough fuel for starting. This is common. If this is the case, your car will not run well passed about 3500rpm because the fuel pump isn't supporting it.
[25% likelihood] something else
Old 06-06-2010, 09:04 PM
0/11 sssss1143
alright thanks. got the tune up done. fuel filter, plugs wire, and air filter. anyways now if i keep the first turn held long enough it will start, im going to run some fuel injection cleaner in it and see what happens. once its started it runs completely fine. hopeing it not the fuel pump. dont feel like spending that much. lol.
Old 06-06-2010, 09:21 PM
skinnyg's Avatar
0/11 ssssss828
Im going to guess either a weak fuel pump (or bad seal in it letting the pressure leak back into the tank) or leaky injectors which drip fuel into combustion chamber all night and then when you try to fire it up it is pretty much flooded and takes a lil but to fire up. Try this, next time turn your key on but dont start, keep your radio and AC off, you should hear the fuel pump prime, do it again, do it like 3 or 4 times, then turn it the whole way forward to fire it. What this does is build pressure back up if its bleeding off
im starting new xjoeyc23x General Car Audio Discussion & Questions 1 05-31-2010 10:05 PM
problem with 3kwp [Problem Solved] jizazz12 (Crescendo) 10 04-30-2010 06:46 AM
new guy here starting over sirgaryhimself13 New Member Orientation 6 02-08-2010 07:12 AM
The box's are starting to come in :D tater Off Topic Chat 77 10-13-2009 10:52 PM
Considering starting mma aturcotte127317 Sports and Fitness 38 03-29-2009 09:44 AM
