Car Help! Please Help! - Car Audio Classifieds!
Old 07-16-2010, 09:20 PM
its_ray_ray's Avatar
OCD Member
0/11 sssss5696
Feedback Score: 23 reviews
Default Car Help! Please Help!
to make it plain and simple. 1999 Mazda 626 lx. i ran outta gas. car won't start. what should i do?
i have been reading up. and most of the things i have read say. fuel pump is dry so i need to put alot of gas into it b/c of pressure issues or something?
anybody have any suggestions?
Old 07-16-2010, 09:27 PM
sound_around's Avatar
0/11 sssss9691
Are you 100% sure it was out of gas?
Old 07-16-2010, 09:28 PM
0/11 sssss9691
Fuel pump or fuel pump relay.What engine?
Old 07-16-2010, 09:32 PM
OCD Member
0/11 sssss5696
I'm about 99.9% it was out of gas. i pulled into where i usually park and it stuttered and shut down as if i ran out of gas here is the engine
1998–1999 2.0 L F I4 125 hp (93 kW) 127 lb·ft (172 N·m)
Mazda F engine - Wikipedia, the free encyclopedia
Old 07-16-2010, 09:37 PM
0/11 sssss9691
Open the gas cap and listen very carefully while somebody else turns the key to the run position (do not start but key all the way on).If your fuel pump is working you should hear an electric motor type wine.try it a few times and tell me if you hear it running when you cycle the key on
Old 07-16-2010, 09:38 PM
0/11 ssssss137
If the fuel pump is running and it still isn't starting after you fill it up check the fuel filter. All the junk that floats around in your tank will get sucked up into the filter when you run it dry.
Old 07-16-2010, 09:41 PM
OCD Member
0/11 sssss5696
yeah i know that wine. usually happens when ur running low. u can clearly hear it.
I have no honest clue where the fuel filter would be. lol. where could i find it lol. or a general area.
0/11 sssss9691
Good call but IME a clogged filter will usually let the engine start or hard start and idle rough or smooth but the second you touch the gas it will die.
Old 07-16-2010, 09:42 PM
0/11 sssss9691
Check for spark my man
Old 07-16-2010, 09:43 PM
0/11 sssss9691
or try to find the schrader valve on the fuel rail and test it for any kind of pressure
