Car Radiator Talk - - Car Audio Classifieds!
Old 07-21-2010, 08:05 AM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
Default Car Radiator Talk -
Got a 94 prelude that had a radiator leak i found that the reseviors cap wasnt screwed on tight so water was spitting out.
refilled it back up and screwed top on tight... car is still overheating now... i think something got damaged when the car initially overheated... what needs to be replaced thats causing it to over heat now?
you probably wont like me
Old 07-21-2010, 08:06 AM
upzaw2000's Avatar
0/11 ssss14427
radiator take a poop?
Old 07-21-2010, 08:08 AM
Derrick824's Avatar
0/11 sssss2362
Feedback Score: 56 reviews
Make sure there isn't any air in the system.
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
Air bubble in the system. Thermostat bad. Warm the car up and feel the upper and lower radiator hose. If both are about the same temp the thermostat is probably open, if they are significantly different its probably not open.
Old 07-21-2010, 08:14 AM
98AckCL23's Avatar
0/11 sssss9929
The radiator is basically a tank. It doesn't exactly take a poop. There may be some damage on the fins, but that's something you should be able to see by looking at the front of it. If you can't, then pull it out (really not that hard, I did it on my Acura which has a very similar mounting system as the Prelude) and check it.
Are the fans still coming on? Water pump still working?
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 07-21-2010, 08:15 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
The top should be hot as fawk, the bottom should be a LOT cooler. (That is what the radiator is for)
If you can safely get to it, feel around on the radiator for cold spots. If you have a large cold area the rad is plugged up.
Check your earl for coolant in it. (It will look like a milkshake)
Check your radiator for exhaust gasses coming out of it. (they make a tester that you fill with a test fluid and pump the turkey baster like bulb to suck air in at the opening of the radiator to check for exhaust gases coming out of it.) but you can normally see it/smell it.
If you have either of the last 2 symptoms you have a head gasket blown.
Smoke from the exhaust is the more common sign of a head gasket though.
Your main issue is the emblem on the front of it though.
Now I will move this to the automotive section where it belongs. Noob.
Team CACO Team SHOK
Supporting Member
Old 07-21-2010, 08:18 AM
0/11 sssss6190
Hey...
Hondas run forever.
The craigslist ads for the 91 Civics with 250k for 3k tell me so.
Old 07-21-2010, 08:23 AM
upzaw2000's Avatar
0/11 ssss14427
ok lets say theres an air bubble... how do u fix that...
no smoke it in yet but after it overheated yesterday u could hear steam escaping for a few minutes after it was turned off. Fans are working great.
When i get home ill check the hoses.... and placing my hand on the radiator sounds sketchy but ok... So the bottom part should be cool but not too cool?
Old 07-21-2010, 08:24 AM
upzaw2000's Avatar
0/11 ssss14427
water pump is good too sry
Old 07-21-2010, 08:30 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
If you know what you are doing there is nothing wrong with putting your hand on the radiator. The upper rad hose will be hotter. Unplug the fan (probably fans) so neither one can turn on and once the t-stat opens and the upper hose builds pressure (water cooling systems usually pressurize to ~15lbs) feel around on the rad through the fans.
It IS dangerous because I know idiots out there will forget to unplug the fans and they will kick on while their hand is stuck through it (Most fans have grilles over them now so you can't do that)
You don't want to run the car for TOO long with the fans off because it will get hot quick, but you can still see if your rad is blocked up.
and yes, the upper rad hose should be hot enough you can barely stand to touch it (You will probably cry like a baby because I know you ) and the lower should be considerably cooler.
Team CACO Team SHOK
Supporting Member
Passive radiator? basshead08 General Car Audio Discussion & Questions 0 03-02-2010 07:27 AM
[SOLD] 10" Passive Radiator KeepinItSimple Speaker Accessories & Parts 9 11-30-2009 09:20 PM
[Sold]Like New Boston G3 w/ Passive Radiator KeepinItSimple 10" Subwoofers 0 11-26-2009 02:50 PM
WTB TC Sounds VMP Passive Radiator(s) maintrain Wanting to Buy (WTB) 11 10-19-2009 12:50 PM
Ebay radiator? Bushj311 General Automotive Chat 4 08-01-2009 10:04 PM
