How to decide size of tires? - Car Audio Classifieds!
Old 01-06-2009, 06:40 PM
aturcotte127317's Avatar
Veteran Member
0/11 sssss3613
Default How to decide size of tires?
so the tires on my rims now are 225/45/(ZR) 17 i am not sure what the ZR is maybe someone can help me with that too? but my question is, if i want the tires to be more low profile, which of the numbers do i change?? (i am guessign the 45?) please any and all help, thanks!
147.5 sealed on dash
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 01-06-2009, 06:43 PM
allout13's Avatar
0/11 ssssss822
yeah its the middle number that affects the profile
Old 01-06-2009, 06:45 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Tires size
225/45/ZR17 =
Tire is 225mm wide
the height of the tire is 45% of the width
The tire is ZR speed rated, different letters mean the tire is safe for use at different top speeds.
17 = rim size.
When changing tire size you need to keep the overall diameter (rolling diameter) of the tire the same. If you want lower profile tires you need to get wider and shorter tires to keep the rolling diameter the same.
In your case I would sugges going to a 235/40/17. You might be able to get away with a 245/35/17 but you need to make sure you rim is wide enough to fit the tire.
/ CAAA Member #2 /
Old 01-06-2009, 06:53 PM
0/11 sssss1560
you make the tire wider?
Old 01-06-2009, 06:55 PM
Veteran Member
0/11 sssss3613
Originally Posted by SPY View Post
Tires size
225/45/ZR17 =
Tire is 225mm wide
17 = rim size.
yea im confused, to run 235/40 wouldnt i have to change the rim to a wider rim??
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 01-06-2009, 06:56 PM
SPY SPY is offline
0/11 ssss10192
yes, to keep the diameter the same you must make the tire wider to make the aspect ratio smaller.
/ CAAA Member #2 /
Old 01-06-2009, 06:58 PM
Veteran Member
0/11 sssss3613
but for a wider tire, wouldn't i need a wider rim?
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 01-06-2009, 07:01 PM
SPY SPY is offline
0/11 ssss10192
depends on the size of your rim.
I run a 235/50/17 for summer tires and a 225/55/17 for snow tires, my rims are 17x7.5 and both size tires fit fine and have an almost identical rolling diameter.
/ CAAA Member #2 /
Old 01-06-2009, 07:02 PM
0/11 sssss1560
well thats cool you dont have to change your speedo twice a year
Old 01-06-2009, 07:06 PM
Veteran Member
0/11 sssss3613
alright i get it, but im just gonna stick with the 225/45 thanks guys!!!
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
WTT: Set of 18" CHROME Wheels & Tires danteBirosel Car Audio Trader (WTT) 0 12-01-2008 06:27 PM
Increase your brain size, literally Cheesemind Off Topic Chat 2 11-02-2008 08:16 AM
24" DUB wheel/tires Ricoshay Miscellaneous Stuff For Sale 4 10-01-2008 09:50 AM
WTB: 18's or 19's +40 or less, 5x114.3 w/tires and possible trade for.. nismos14 Miscellaneous Stuff For Sale 8 09-19-2008 10:57 AM
