What is this??????? - Car Audio Classifieds!
Old 08-07-2010, 01:26 PM
0/11 ssssss178
Default What is this???????
Hey this is probably a dumb question but does any one know what this part is called (the thing with the rubbed thing on it) its on my 2001 jeep grand cherokee larado it goes to my 4x4 im pretty sure its the front drive shaft but just making sure and i need to replace it but i need to find out what its called before i can get a quote.
-Any help will be great thanks
Old 08-07-2010, 01:30 PM
SOS71's Avatar
0/11 sssssss68
Looks like a U-Joint the rubber is just a cover for it to keep debris out...
Old 08-07-2010, 01:47 PM
Ego Crusher
0/11 sssss1834
its your drive shaft and then thing with the boot over it would be the u joint thats a strange design though
06 trailblazer ss (Ego crusher)
Texas speed forged 408,custom cam, stalled
hp numbers coming soon
focal 4.160,fosgate coax in rear doors
popcorn sounds 6k ,2 sundown sa15, in a 6th
Old 08-07-2010, 02:02 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
it might be a c/v (constant velocity) joint
not that that is what it is, but that's what it looks like
who wants a nudel ride?
Old 08-07-2010, 02:06 PM
indytrucks's Avatar
CACO Late Night Crew
0/11 sssss5387
Ding, ding, ding! Thats what it is. Go to a junk yard and find one. You can get full shafts for next to nothing. WAY cheaper than buying a new one. Just make sure the donor has the same T-case as your Jeep and you'll be fine.
Old 08-07-2010, 02:11 PM
indytrucks's Avatar
0/11 sssss5387
Hell, if you would have read the caption from JP magazine, where you got that pic from, it says right there:
Another area of drivetrain noise can be the front driveshaft. This is especially true on 4.7L Quadra-Drive models. The front driveshaft's CV joints seem to wear a bit faster than regular U-joints or Double Cardan-equipped shafts. Crown carries replacement parts. Also note the weeping pinion seal. We'll deal with that later if and when we re-gear for larger tires
Old 08-07-2010, 02:48 PM
0/11 ssssss178
ok so if i go to a junk yard an get one do i just ask for a front drive shaft for my 4x4?
Old 08-07-2010, 02:53 PM
indytrucks's Avatar
0/11 sssss5387
What year is your Jeep? What t-case do you have? That is going to be important. There is a full time 4wd, part time 4wd, and all wheel drive G.C. You need to make sure you get the right drive shaft for YOUR jeep when you get it.
Old 08-07-2010, 03:08 PM
0/11 ssssss178
its a 2001 and it has a second shifter for 2wd 4 part time 4 full time ndown 4 low i think i dont remember the jeep is at my other house in Texas im going to go pick it up but im trying to get the part for it now so i can throw it on when i get there.
Old 08-07-2010, 04:15 PM
0/11 ssssss178
and i need the hole bar piece conected to cv joint so what is all that called?
