oil pressure drop... - Car Audio Classifieds!
Old 08-12-2010, 02:16 PM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
Default oil pressure drop...
after my truck warms up the oil pressure drops to about 20... 40 is the middle mark on the dash...
tis normal?
you probably wont like me
Old 08-12-2010, 02:19 PM
sound_around's Avatar
0/11 sssss9691
At idle yes.
Rule of thumb is 10psi for every 1000rpm
Also on the 4.3 GM the oil pressure sending unit located behind and below the distributor is notorious for failing.
Old 08-12-2010, 02:30 PM
upzaw2000's Avatar
0/11 ssss14427
oil pressure sending unit? not sure what the is.... is that just a signal saying its low pressure but really isnt?
also there is no RPM meter on my truck but i can tell its idling pretty low... i guess i figure out how to up the idle on it.
Old 08-12-2010, 02:31 PM
upzaw2000's Avatar
0/11 ssss14427
i figure for ur rule of thumb thing... that its normal then i just need to bump the idle up... where jpwesieck (i totally bombed his name) im sure he knows where the idle is...
Old 08-12-2010, 05:53 PM
0/11 ssssss185
does it go back up while your giving it gas?? like you stop at a red light it drops, you take off on green it goes back up? or does it drop and stay down.
Old 08-13-2010, 04:53 PM
upzaw2000's Avatar
0/11 ssss14427
ya when i speed up it goes up to 40 again but just at idle it drops.. .when its warming up tho... it stays at 30-40
Old 08-13-2010, 05:17 PM
Kicker Guy's Avatar
0/11 ssssss355
I have had many 4.3's, it is normal for them to have low oil pressure on idle when warm. Dont worry about it
Old 08-13-2010, 05:21 PM
joebobclark's Avatar
Your Moms New Boyfriend
0/11 ssssss985
Feedback Score: 22 reviews
What weight oil are you running? If its 5w30 or so, and its hot out, I wouldnt be suprised...
If the truck has higher miles (100,000+) I wouldnt run less than 10w40 in it and would probably run 20w50 in the summer....
2005 S10 Blazer 2-door
**** Under Construction****
Old 08-13-2010, 05:26 PM
0/11 sssssss65
one its warmed up it normal for it to drop around 20-25 psi
Old 08-13-2010, 05:36 PM
upzaw2000's Avatar
0/11 ssss14427
Thanks
used FI q drop in re cone AlanHall Speaker Accessories & Parts 4 08-18-2010 06:26 PM
4.0L v6 oil pressure? splvictim20 General Automotive Chat 3 03-09-2010 10:03 PM
Pressure Sensor MopaRBumpiN General Car Audio Discussion & Questions 25 01-25-2010 06:51 PM
Voltage drop?? king ranch General Car Audio Discussion & Questions 15 12-02-2009 07:01 PM
2004 Ford Explorer build - pure pressure audio anj46907 Build Logs 19 09-26-2009 01:24 AM
