hid ?? - Car Audio Classifieds!
Old 08-12-2010, 09:07 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Feedback Score: 22 reviews
Default hid ??
i just put hid's in my 98 explorer and i was just wondering if it is normal for my "brights light" on my dash to be lit?
they are 8000k 35w "Xenon HID's"
Old 08-12-2010, 09:15 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
any ideas
Old 08-12-2010, 09:19 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Bumping a thread 8 minutes after you make it doesn't help any.
Does it never go out? Do you have a hi/lo kit? Did you get the error eliminator (I believe fords are notorious for problems with HID's.)
Team CACO Team SHOK
Supporting Member
Old 08-12-2010, 09:22 PM
get_low's Avatar
I like tater tots!
0/11 ssssss951
I have a 97 limited with 55w 6000k H.I.Ds and my "brights" indicator isn't lit up when they are on.... Although my message center says "check lights" when they turn on, you just hit reset and it's good to go...
[email protected] sealed legal
Old 08-12-2010, 09:23 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
ehh just a lil cautious is all. i believe its a hi/lo kit. whats the error eliminator. but when i turn the brights on the dash light glows a lil bit brighter
Old 08-12-2010, 09:25 PM
Prohibited Sellers/Buyers
0/11 sssss6709
Feedback Score: 17 reviews
i had this issue before with customers install i did he had a DRL relay though that had to be pulled.
Old 08-12-2010, 09:26 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
theres no relays. pretty simple install
Old 08-12-2010, 09:34 PM
get_low's Avatar
I like tater tots!
0/11 ssssss951
That might be your problem. I always install H.I.Ds with the relay harness and never have any problems like this...
HID Kits, BMW Aftermarket Bumpers & Lighting, DEPO - DDM Tuning
If thats not the issue I dunno what to tell you lol my DRL works fine and everything like I said, just the message center says check lights, you just hit reset and its good to go... Maybe mine's different cus it's a year older?
Maybe check out Ford Explorer and Ranger Enthusiast Forums - Serious Explorations and see if anyone has had your same problem before
Old 08-12-2010, 09:38 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
what does the relay connect to and is it something i can add to mine
Old 08-12-2010, 09:40 PM
get_low's Avatar
I like tater tots!
0/11 ssssss951
It plugs in line(between stock headlight harness and the H.I.D ballast) and uses that as a trigger to turn the relay on, and the H.I.Ds will then get it's power directly from the battery instead of through the stock wiring.
