How to cut sheet metal in the door? - Car Audio Classifieds!
Old 08-13-2010, 06:09 PM
groundpound4200's Avatar
Errday I'm Hustlin'
0/11 sssss1785
Default How to cut sheet metal in the door?
I am putting some ID OEMs in the doors of my Honda Pilot but the magnet is too big to clear the precut hole. How could I cut this out without butchering up my door too bad? Here's a pic of what I'm working with
2007 Honda Pilot
Sundown SAZ 1500D V.3
2 Atomic APX 818 10"s
Taylor Lampart aka NewAgeKing
Old 08-13-2010, 06:11 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
best bet, but maybe most time consuming would be to use a corded drill with a high grit metal sand paper on a sindle attachment. It could take a while but using any sort of saw will make that hack job effect your trying to avoid.
Old 08-13-2010, 06:12 PM
tin snips
Old 08-13-2010, 06:13 PM
AudioAnonymous's Avatar
0/11 sssss1723
sawzall with short fine- toothed blade and a steady hand
CACTUS SOUNDS
2006 db drag WF 3rd place 161.2 SM3-4
2007 db drag WF 1st place 163.4 SM3-4
Loudest to date 165.9 SS3-4 with borrowed equipment
2010,2011 db Drag World Finals judge.
Old 08-13-2010, 06:14 PM
Finally Back to Work.
0/11 ssssss833
this...
but i've never tried on a door, so i didn't want to suggest something I have never tried. shouldn't be too hard though.
Kenny Cox
I go through more variations of car audio than any "beginner" you will ever meet!
Old 08-13-2010, 06:17 PM
lileddie1127's Avatar
0/11 sssss1225
sawzall and take your time.
6th order coming soon!
Team Juggernauts
Old 08-13-2010, 06:18 PM
0/11 ssssss147
id suggest a sawzall like they mentioned and then taking some sand paper to it to even it out and give it a nicer finish
Old 08-13-2010, 06:21 PM
djm4rshm2llow's Avatar
151.8 and climbing :D
0/11 sssss2169
Feedback Score: 24 reviews
Sawzall in little grooves all the way around, then hit the little cuts with a hammer and it will start to bend back alittle at a time. Thats what i did in my car. (honda accord)
Old 08-13-2010, 06:23 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Dremel and a cutoff wheel.
Worked great for my doors.
/ CAAA Member #2 /
Old 08-13-2010, 06:24 PM
how far do you need to go? my pickup I just used a hammer and bent the metal out until it fit
Is my cut sheet right? SQL Monte Enclosure Discussion & Design Construction Help 4 06-29-2010 09:32 AM
box cut sheet MiX Enclosure Discussion & Design Construction Help 5 05-03-2010 10:21 AM
need help w/ cut sheet? SacTownBully84 Enclosure Discussion & Design Construction Help 8 04-12-2010 09:00 AM
cut sheet program.... DonH General Car Audio Discussion & Questions 4 09-17-2009 07:39 AM
Price sheet needed. RollerDJ (Sundown Audio) 10 02-07-2009 08:18 AM
