Diesel Engines?? - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > The OT > General Automotive Chat
Old 10-03-2010, 10:18 AM
headshok's Avatar
Loyal Member
0/11 sssss1428
Default Diesel Engines??
hi guys,
I will be changing out my ride to a little mini truck ( its a mitsubishi L200 Triton), with a 2.5L Turbo Diesel Engine.
Performance wise, what can be done to diesel engines?
Tuning? wat kinda mods can i look at?
Just seeing my options
THanks in advance guys
cheers!
email me at
to get prices on our cables! Prices will not be posted online
Old 10-03-2010, 10:21 AM
Violence*'s Avatar
OCD Member
0/11 sssss7568
Feedback Score: 41 reviews
that motor im not sure. but most guys upgrade turbos, exhaust, injectors, turbo manifolds. but on the 2.5L im not sure what parts there are.
Old 10-03-2010, 10:24 AM
0/11 ssss31258
to get better performance out of a diesel...
let it breath!
it's only a 2.5L so a 3" intake and 3" exhaust will do.
Then turn up the fuel pump.
If I had a diesel mini.. and it was a standard cab long bed... you'd better believe I'd have stacks
Old 10-03-2010, 10:32 AM
sound_around's Avatar
0/11 sssss9691
Water and methanol injection seem to be getting more popular on Diesels.
Old 10-03-2010, 10:38 AM
headshok's Avatar
Loyal Member
0/11 sssss1428
hi guys
thanks!
Here's more info on my truck
Mitsubishi Triton - Wikipedia, the free encyclopedia
i test drove the truck b4,
power is in the 1k to 2k rpm range.
after that it kinda loses steam..
anyway, just kinda curious to see what stuff can be done to this little truck
Thanks guys
cheers!
email me at
Old 10-03-2010, 10:43 AM
0/11 sssss9691
I don't know what exact engine you have but this is the info on all of them.
4D56
Displacement - 2.5 L (2,476 cc)
Bore - 91.1 mm
Stroke - 95.0 mm
Fuel type - Diesel
[edit] Non-Turbo
  • Power - 51 kW (68 hp) @ 4200 rpm
  • Torque - 142 Nm (105 ftlb) @ 2500 rpm
  • Engine type - Inline 4 cylinder SOHC
  • Fuel system - Distribution type jet pump
  • Compression ratio - 21:1
[edit] Non-intercooled Turbo (TD04 Turbo)
  • Power - 67 kW (90 hp) @ 4200 rpm
  • Torque - 197 Nm (145 ftlb) @ 2000 rpm
  • Compression ratio - 21:1[10]
[edit] Intercooled Turbo (TD04 watercooled Turbo)
  • Power - 78 kW (104 hp) @ 4200 rpm
  • Torque - 240 Nm (177 ftlb) @ 2000 rpm
[edit] Intercooled Turbo (1st Generation DI-D)
  • Power - 85 kW (114 hp) @ 4000 rpm
  • Torque - 247 Nm (182 ftlb) @ 2000 rpm
  • Fuel system - 1st Generation Common Rail Direct Injection (CRDi)
  • Compression ratio - 17:1[11][12][13]
[edit] Intercooled Turbo (2nd Generation DI-D)
  • Power - 103 kW (138 hp) @ 4000 rpm
  • Torque - 320 Nm (236 ftlb) @ 2000 rpm
  • Fuel system - 2nd Generation Common Rail Direct Injection (CRDi)
  • Compression ratio - 17:1[14][15][16][17]
[edit] Intercooled Turbo (3rd Generation DI-D with variable geometry turbo)
  • Power - 130 kW (175 hp) @ 4000 rpm
  • Torque - 400 Nm (295 ftlb) @ 2000 rpm
  • Compression ratio - 16.5:1[18]
Applications:
  • 2001-present Mitsubishi Space Gear/Triton/L200/Strada
  • 2009-present Mitsubishi PajeroSport/MonteroSport
Old 10-03-2010, 10:47 AM
keifersracing's Avatar
Team Roto Rooter
0/11 sssss1407
add some propan
Old 10-03-2010, 12:45 PM
bones22's Avatar
0/11 ssss12257
aftermarket turbo
larger exhaust
upgrade intercooler
injectors
please never put stacks on it. they only belong on big rigs, mud/swamp vehicles so they dont suck water in, Dodge Little Red Express (stock), tractors, garbage trucks
Old 10-03-2010, 01:04 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Originally Posted by bones22 View Post
aftermarket turbo
larger exhaust
upgrade intercooler
injectors
I disagree I like stacks on trucks. Stacks on a mini truck would be sick IMO. He needs stacks so his pipes won't drag on the ground...
Old 10-03-2010, 01:06 PM
FatBoy2's Avatar
That was crafty.
0/11 sssss1790
lol.
Fo eights in da pickup!
Anyone run wvo/svo in their diesel engine? terra General Automotive Chat 14 05-27-2010 01:29 AM
anyone ever big 3 a diesel? michael707 General Car Audio Discussion & Questions 7 09-10-2009 06:21 PM
Vids for rednecks (Diesel) 92K1500 General Automotive Chat 90 08-18-2009 02:43 AM
1980 VW Rabbit Diesel YelLow Rabbit Build Logs 24 08-12-2009 07:15 AM
Porsche 4 Cylinder Engines to be Sold Patrick Simmons General Automotive Chat 0 09-17-2008 10:17 AM
