1993 Explorer Clutch Trouble - Car Audio Classifieds!
Old 10-03-2010, 09:39 PM
Derrick824's Avatar
0/11 sssss2362
Feedback Score: 56 reviews
Default 1993 Explorer Clutch Trouble
1993 Ford Explorer sport 2wd 5spd
Truck has a brand new clutch kit. Pedal went limp, figured it was the slave cylinder. Old slave cylinder looked fine upon removal but swapped in a new one anyway. Didn't fix the problem. Bled all air from the system. Already pulled the master cylinder and it looks fine but gonna swap in a new one in the morning anyway.
Anyone have any thoughts on what else it could be?
Also, I could strangle the Ford engineer that thought it was a good idea to install the slave cylinder inside the bell housing. Freakin idiots. Had to pull the transmission just to change the slave cylinder.
Old 10-03-2010, 09:42 PM
sound_around's Avatar
0/11 sssss9691
Master cylinder.Also fords take FOREVER to bleed.
EDIT* Wanted to add that after you change the master out you can try to let it gravity bleed for an hour or 2.It may make bleeding faster for you.
Old 10-04-2010, 12:36 PM
Derrick824's Avatar
0/11 sssss2362
Installed the new master cylinder this morning. Didn't fix it. The only part left in the system is the clutch hose that runs from the master to slave cylinder. Dealership item that cost $88 dollars.
Since I now have the entire old assembly outside of the vehicle we hooked it all up and ran water through for testing. Everything works perfect. Master cylinder pumps, slave cylinder moves freely, and all hoses are clear.
I thought we had just put this clutch kit in last Christmas but looked it up and it was two years ago. Clutch still engages fine inside the transmission. I can crank the truck in gear and drive it, just can't shift gears. Checked out the slave cylinder through the access hole in the transmission and it seems to be fully extended against the pressure plate (explains why I have no pedal pressure). Now I'm really confused. I'm no expert but I would think that the transmission would be stuck in neutral at this point yet it's the opposite.
I'm guessing the next step is a new clutch kit.
Old 10-04-2010, 12:52 PM
0/11 sssss9691
Throwout bearing may have collapsed some or maybe the clutch fingers or the springs on the pressure plate are failing.
With the system off the truck there is pressure on the slave rod to test accurately.
Old 10-04-2010, 12:56 PM
mhart's Avatar
0/11 ssssss721
didn't mazda make those manual transmissions?
'00 civic si IASCA stock trunk/pickup 1 World Record Holder
'01 S-10
Team DC Audio Team XS Power Team ISB
Steve's Body Shop
Old 10-04-2010, 12:58 PM
Derrick824's Avatar
0/11 sssss2362
Yes.
Old 10-04-2010, 01:05 PM
0/11 sssss9691
The Mazda built m5od series can be found on tons of cars and has proven to be a decent product.
Mazda M5OD transmission - Wikipedia, the free encyclopedia
Old 10-04-2010, 07:45 PM
Derrick824's Avatar
0/11 sssss2362
Finally got it fixed. The main issue was a bad slave cylinder but it caused a second issue, air in the master cylinder. Apparently these models in particular are really bad about getting air trapped in them and the only way to get it out is to unbolt the master cylinder and bleed it upside down. What a pain! I got lucky and found a clutch website that described the problem and fix in detail & even had a 8min youtube vid about it.
Old 10-04-2010, 09:44 PM
0/11 sssssss45
glad to hear you got it fixed. anything with brakes or a transmission are usually a real pita.
Old 10-04-2010, 09:56 PM
0/11 sssss9691
Very nice!You make me miss my AWD 5speed Exploder.....And all 5 Supercoupes
I have had to do that (upside down bleeding) before myself but for some reason I forgot all about it.
Question about the clutch slave cylinder themgators511 General Automotive Chat 8 08-05-2010 02:04 PM
Price DROPPED! $225! GAMING! Racing wheel with 6 speed shifter and clutch nismos14 Miscellaneous Stuff For Sale 7 04-07-2010 09:48 AM
Clutch took a poop toad559 General Automotive Chat 1 01-07-2010 01:49 AM
1993 Lincoln Continental westman995 Build Logs 59 10-18-2009 08:52 AM
CRX Clutch MaTT6387 General Automotive Chat 22 06-08-2009 01:18 PM
