somone help me truck issues. - Car Audio Classifieds!
Old 10-09-2010, 11:44 PM
Prohibited Sellers/Buyers
0/11 sssss6709
Feedback Score: 17 reviews
Default somone help me truck issues.
Can anyone help me.
well guy's i put both new o2 sensor's on they deff. were shot but went and also had fuel fuel system cleaner sent through motor and got all carbon emisson deposit's etc...out it and it was running good when left friends shop. but same thing let it sit for a little bit started up and what do ya know it's back to running like hell. this sux i hate not having a daily driver it's to the point where its choking itself in middle of traffic and i can punch it to the floor and barely be doing 30mph at all. i rented a fuel pressure tester for $180 luckly i get that back cause its just a deposit at my work but if my fuel pressure is down more then likely i need a fuel pump that's more cash outta my pocket this sucks so bad. I've got so much bs on my plate right now i feel like i never get a break right when u think thing's are getting good.
Old 10-09-2010, 11:55 PM
0/11 ssssss256
sounds like cats are clogged.
Originally Posted by kickerfanatic
WOW.. thats just an insult...........
I disagree I beileive semen should be good for his throat.
Old 10-10-2010, 12:05 AM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
^^^X2 you just got all that crud out and now they could be clogged
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Old 10-10-2010, 01:18 AM
0/11 sssss6709
I was thinkn about that i have one but if u hit the cat doesn't rattle or anything just sound's pretty solid.
Old 10-10-2010, 01:39 AM
0/11 ssssss256
it doesnt have to rattle bro! a lot of times, when u get ur engine get a fuel system service, the engine is not able to burn all the cleaner. That cleaner goes to ur cats get wet(hahahaha wet cat! hahahahah) it plugs, not only from the cleaner but also from any unburned fuel that a faulty spark plug, wire or leaky injector let thru. get a set of straight pipes or open the exhaust system drive around and see if it runs better.
Old 10-10-2010, 01:50 AM
0/11 sssss6709
Im so ready to just run open pipes on this damn truck lol. run another flow master hahaha my neighbor's they hate me enough for my loud hot rod already. yeah man i had a full fuel system cleaner through my friend's shop sent it through the vacumm line that connect's to the brake booster. cleaned all crud/etc.....out ran great for bout 15to20 mins i drove it like 10mins back home ate some lunch let it sit about half hour came back out from eating lunch and what a suprise it's back to running like shit again. 2moro fuel pressure test and if that's fine that cat is coming out and im just gonna throw straight pipe in replace of the cat.
Old 10-10-2010, 01:57 AM
0/11 ssssss256
maybe the cylinders still loaded from the cleaner and the gas, disconnect the fuel pump fuse or EFI and crank the truck, make sure u got a good battery, hahahahahaha! im pretty sure u got couple laying around, by cranking with no start and no fuel u be cleaning the engine or any extra fuel/cleaner. GL
Old 10-10-2010, 02:05 AM
0/11 sssss6709
Never thought of that also ill try that 2morro i gotta get some rest up early 2morro 2 work on it b4 work thanks man ill keep ya updated.
Old 10-10-2010, 02:10 AM
0/11 ssssss256
cool dude! let me know!
Old 10-10-2010, 08:56 AM
0/11 sssss1877
Feedback Score: 26 reviews
If you have low fuel pressure its either the pump or filter. Would just cut the cats off anyway cause thats Bad ass
this could cause some issues Memphistahoe02 Off Topic Chat 22 03-25-2010 02:43 PM
Aol issues? tc3k101 Off Topic Chat 16 02-26-2010 07:35 PM
About RD CS issues BigC-Expo Off Topic Chat 87 11-18-2009 12:07 AM
Which Mini truck would you get? - Looking to build an SPL truck old CACO Admin General Car Audio Discussion & Questions 22 10-11-2009 10:13 PM
HID Issues NoPh33rRaCiNg General Automotive Chat 21 09-21-2009 06:41 AM
