(ABS) light - Car Audio Classifieds!
Old 10-12-2010, 08:34 PM
chuck5766's Avatar
GPI Respect The Movement
0/11 sssss2191
Feedback Score: 24 reviews
Default (ABS) light
ok i drive a 98 chevy blazer and today the (ABS) light came on for no reason so what would make this come on and how can i fix it ?
TEAM
G.P.I ..!!.. Respect The Movement ..!!..
Old 10-12-2010, 08:38 PM
Gabriel ruiz's Avatar
0/11 sssss1458
Feedback Score: 37 reviews
check your brake fluid if low check your brake lines for any leaks and also the brakes if you dont find a leak and none of those places just fill your master cylinder and see what happens thats all i got before i start getting more deep into it
sound_around's Avatar
0/11 sssss9691
Probably an ABS sensor.Sometimes a sign that a wheel bearing is going out in the front.A common GM truck issue.
Old 10-12-2010, 08:39 PM
extremechevyman67's Avatar
Loyal Member
0/11 sssss2278
Feedback Score: 42 reviews
mine came on, on my 02 extreme an my, blazer i have now its the abs sensor i just dont pay attn to it. but if u want replace the sensor
SOLD TO quaddropper, atxbasshead, chuck5766, MrFixIt, Austin175, mwerling1212, Boomsday, maverickdog8, ed70805, SPL
, extreme, soundaround, all_rice, ampjunkielikeme, DonH, Wheres The Butta, lantzdarla, Tcartney, Slam, cuseikan, sleepingciv, rachidfunaki, RidnClean
TRADED WITH 00ram360, chuck5766, SacTownBully84, blfuller123, RobTabor
BOUGHT FROM slim2fattycake, imasonic
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Lots of things can make it come on.
Bad ABS computer, bad sensor in the in the metering block doohickey that I can't think of the name of, leak in a brake line, bad ABS sensor, bad tone ring, having one set of tires turn and not the other (having your drive axle jacked up and having the tires spinning by using the engine), bad brake switch etc...
Does the light stay on even after cycling the key?
Is your truck 4x4?
The light is really nothing that big to worry about. It just means your ABS isn't working right and has disabled itself. You still have standard brakes that will lock up in rain/snow, so you have to be more careful and remember to pump your brakes instead of holding them down when you get in a skid.
Team CACO Team SHOK
Supporting Member
Old 10-12-2010, 08:40 PM
notloudenuff's Avatar
0/11 ssssss573
lol, mine is a 96' and has the same issue. it shuts of every now and then. i just ignore it cause i hate ABS!
Old 10-12-2010, 08:42 PM
FOGEL A.KA.MCLOVIN's Avatar
0/11 ssssss307
my dads 2000 silverado did the same thing, just ignore it. if you notice breaks start to lock up take the abs fuse out and you'll be fine
Old 10-12-2010, 08:44 PM
abs is garbage anyway
Old 10-12-2010, 08:47 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Troofness.
Team CACO Team SHOK
Supporting Member
Old 10-12-2010, 08:48 PM
0/11 sssss9691
Good on the road lousy off it.
light subs fiBl18 General Car Audio Discussion & Questions 3 09-03-2010 09:40 PM
Best Bud Light Commercial duramaxxed Off Topic Chat 4 01-18-2010 03:28 PM
i can see the light snoopysnooper Uncensored Off Topic 13 10-01-2009 06:16 PM
Light Box blackhawk Announcements - Suggestions - Feedback - Support 1 09-15-2009 10:37 AM
[SOLD]LiteGlow "Light Dancer" Musical Light Controller toolguy420 Wiring, Electrical & Other Installation Equipment 5 09-02-2009 03:12 PM
