Screaming Alternator...Problem? - Car Audio Classifieds!
Old 03-11-2009, 07:15 PM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
Default Screaming Alternator...Problem?
When I start my car, my alternator lets out a lets out a little scream. I really high pitch squeal that sounds like nail on a chalkboard. It is only for a second or 2, and it doesnt happen while I am driving, only starting. It is worse if the car has been sitting for a longer time. I opened the hood and did it and it came from the alt for sure, it was almost like it can't spin as fast at first. It does have a broken plastic cap on it. problem?
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 03-11-2009, 07:16 PM
DLP customs
Guest
0/0 sssssssss
Sounds like the gears just get surface rust in them, no diffrent then breaks squeak when they sit for awile.
Old 03-11-2009, 07:20 PM
0/11 sssss3784
do does I fix?
empty trunk
DC Power 270xp
.... so far
Old 03-11-2009, 07:22 PM
Prohibited Sellers/Buyers
0/11 ssssss327
sounds like maybe you've got low voltage and then the alt squeals when it first starts up.
Next time you do it check voltage on your batteries before you start the car and see what its sitting at...
My old truck would do that when I just had 1 alt on it with all 8 amps...after I burped the voltage would get low and the alt would start squealing...i don't have a technical reason lol
Old 03-14-2009, 09:06 PM
0/11 sssss3784
Okay, now the engine temperature is going up. My girlfriend said this happened to her car and it might be the tranny.
empty trunk
DC Power 270xp
.... so far
Old 03-14-2009, 09:34 PM
toyota thundra's Avatar
TEAM-ADDICTIVE-AUDIO JOSH
0/11 sssss1896
You would know if your tranny was going my friend. The only reason I can see a engine temp rise from a transmission issue, is if the tranny was not shifting causing higher than normal rpms for extended times.
** Team Addictive Audio **
** Team 813 Customs **
** Excessive Amperage HO Alts **
** Seismic Disturbances C.C. Central FL Chapter **
ill call la migra if she gets fake tits.
L00K Here.... IM BACK BEYOTCH!!!!!!
Ive been gone for a while and I seriously missed you guys... Glad to be back.
Old 03-15-2009, 02:54 AM
0/11 sssss3784
fyi my car has been running a lot hotter for no reason.. ever since the squealing started is when the heat started.
empty trunk
DC Power 270xp
.... so far
Old 03-15-2009, 03:46 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Hmmmm.
Try taking your belt off, and see if you can turn everything by hand.
If one is abnormally hard to turn then that might be your problem and the squeal is just your belt slipping a little until it warms up or finally catches good enough to turn whatever is freezing up.
Sounds in cars can be tricky, just because it sounds like it is coming from the alt doesn't mean that really is where it is coming from. I'm thinking maybe your water pump is going out and the belt is slipping on it when it is cold, and since the pump is going out that is letting the temp go up.
Don't run out and buy a water pump because I said that, you still wanna try everything and make sure that is what it is. That is just what I think it could be.
Also you can try taking your belt off and starting it up without the belt and see if it still squeals.
Team CACO Team SHOK
Supporting Member
Old 03-15-2009, 08:12 PM
0/11 sssss3784
that sounds good. thanks! k1500 rep+
empty trunk
DC Power 270xp
.... so far
Old 03-15-2009, 08:17 PM
x2 on the water pump just see if it gets really hot at idle and also check the fluid level if you are loosing coolant and not leaking any on the ground then it's going in the oil (which isn't good) It sounds like your belt is slipping like mentioned before so make sure the water pump pulley spins easily
so i have a problem....... tc3k101 Sound Deadening & Fabrication 24 03-08-2009 01:07 PM
Anyone Else Have This Problem? 92K1500 Announcements - Suggestions - Feedback - Support 21 01-30-2009 08:37 AM
Got a little problem.... jfink General Car Audio Discussion & Questions 18 01-20-2009 07:49 PM
Amp Problem RidnClean General Car Audio Discussion & Questions 10 09-20-2008 04:48 AM
