motor / spark plug help needed. - Car Audio Classifieds!
Old 03-17-2009, 03:58 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
Default motor / spark plug help needed.
So, my 02 nissan sentra spec-v started to get a little bit of a mis-fire in it when i first started up. it's got worse today with it finally pulling a code, being mis-fire cyl #4. so, seeing how i have 91k on this car, first thing that comes to mind is a tuneup. start to pull plugs out, and #2 is all but stuck in there. much tighter than the others, and as i try to loosen it, it started to make some odd noises. witch after hearing that, i stopped before doing any damage to the head. so, questions to you guys.
A) how best to get that bastard out without and damage to motor?
B) should i replace all the coil packs. this car has one per cyl right above the valve cover.
Proud Member of CAAA!
Old 03-17-2009, 04:31 PM
what kind of weird noise?
have you ever replaced them before?
and you coil pack should be fine
Old 03-17-2009, 04:38 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
more of a crackling noise. no, i've never changed them.
Old 03-17-2009, 04:40 PM
toyota thundra's Avatar
TEAM-ADDICTIVE-AUDIO JOSH
0/11 sssss1896
Coil packs usually last a very long time. IF indeed it is a coil pack, just buy one. They can be a little expensive. Put the new coil pack on the cylinder thats missing, and see if it corrects the problem. If not (after all the plugs are changed) Switch to another cylinder. (100+ ea) If the plug is seized, a little PB Blaster will help some. If it is cross threaded, you are screwed to be quite honest, I would think that it is not however as they are probably factory plugs. The sound may just be the washer grinding, and a little more force SHOULD break it loose. I would refrain from using a breaker bar however. If it is cross threaded a machine shop will have to repair the head, and inset a sleeve. Not cheap. If it comes out cross threaded, be sure not to let any bits of metal go into the head. Good luck man, I hope this helps.
** Team Addictive Audio **
** Team 813 Customs **
** Excessive Amperage HO Alts **
** Seismic Disturbances C.C. Central FL Chapter **
ill call la migra if she gets fake tits.
L00K Here.... IM BACK BEYOTCH!!!!!!
Ive been gone for a while and I seriously missed you guys... Glad to be back.
Old 03-17-2009, 05:13 PM
0/11 sssss1896
You also may want to try with the engine hot, as metal is very reactive to temperature. Some kits are made to rethread the hole at home from what I can gather.... Try to tighten the plug, see if it moves.... if it does, spray some more lube on it and back it out... In out in out in out.... it should eventually break free.
Old 03-17-2009, 05:16 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
will do. i'm going to get some plugs tomarrow and if i get a chance, change them out in the evening.
Old 03-17-2009, 05:17 PM
does it rain alot where you live it may have a little rust on it hit it with a penetrating oil and leave it for a day (or night)
Old 03-17-2009, 05:21 PM
0/11 sssss1896
I would first try on a hot engine. I know it sucks, but the heat may loosen the threads. Im sure you have alloy heads. Either diesel or pb blaster or plusgas will get into the threads. Diesel is a old school trick. You may even want to use a fixed 5/8ths or 3/4 socket and untighten it untill it stops and then carefully tap the shandle with a mallet. The shock of force may be enough to break it loose. That is generally better than just pulling hard as f**k, as there is less chance of shearing the tip off. Good luck man, and happy birthday.
Old 03-17-2009, 05:36 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
it's indiana, we have a little of everything.
i maybe brought it a 16th of a turn. nothing much, as i started to hear that noise i stopped before i really messed something up. i think i got some WD at home. i left the shroud over the head off. so i'll start spraying it tonight.
Old 03-17-2009, 10:31 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
I think they should put steel helicoils in anything made of aluminum because aluminum messes up so easy....
But what I would do before buying a coil pack is to just switch it to another cylinder after putting in the new plugs (don't buy the most expensive ones, the copper core works just as good) and see if the misfire moves with the coil. 99% of the time you can not return an electronic part if it has been installed.
Team CACO Team SHOK
Supporting Member
Box build help needed on1wheel01 Enclosure Discussion & Design Construction Help 12 03-08-2009 12:40 AM
[SOLD] F/S:: Orion HCCA motor & Basket (TC9+ motor) bangin_explorer 15" Subwoofers 9 03-05-2009 09:41 PM
recomendations needed waresgaragestereo General Car Audio Discussion & Questions 4 12-29-2008 07:28 PM
Recone needed. RollerDJ General Car Audio Discussion & Questions 0 12-23-2008 05:25 PM
PS3 help needed. RollerDJ Off Topic Chat 21 11-10-2008 09:33 AM
