turbo kit questions - Car Audio Classifieds!
Old 07-11-2011, 04:48 PM
Super Moderators
0/11 sssss9623
Default turbo kit questions
looking into getting more performance out of my new car
its a 2009 acura tsx at base
k24z3 engine
im skeptical about ebay kits as most would be, but would this work for my car?
2009 Acura TSX K24Z3 CAST T3T4 Turbo Charger Kit | eBay
or any suggestions
Old 07-11-2011, 04:54 PM
mcmuffin's Avatar
0/11 sssss3380
it would work for your car... but how long is the real question lol
*** NEW BUILD COMING SOON ***
its a secret for now
Old 07-11-2011, 04:59 PM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
The real problem with Ebay kits is the turbos, wastegates and BOV's. If you buy the kit and save up for a better turbo for awhile then wastegate and BOV it should be fine.
also remember those Ebay kits are rarely all bolt in. they usually need some mods.
Old 07-11-2011, 05:30 PM
528hz's Avatar
0/11 sssss1792
I would HIGHLY suggest surfing Honda-tech for a good, long while. That kit you posted is full of Chinese SHIT...literally. When it comes to turboing a car, do it right the first time. Granted it's going to cost you a lot more than $1200, but at least you won't blow up your motor when you do it properly.
I would seriously piece together a kit, it's not that hard:
intercooler and all piping
downtube from exhaust side of turbo to exhaust piping
turbo
manifold
exhaust
injectors
blow off valve and wastegate.
boost controller (or just use the wastegate spring, but I wouldn't do that)
Walbro in-tank fuel pump (no rising rate externals)
Fuel lines
wideband O2 (for tuning and TRUE A/F ratios)
Gauges: boost, wideband gauge (these are the most important) temp...whatever else you want to add
Exhaust: get a Thermal R&D
And last and certainly the most important part...ECU tuning. If you wanted to really do it proper, go AEM standalone.
Old 07-11-2011, 05:42 PM
TEAMLOWPOUNDERS
0/11 sssss3564
Not sure if Ur acura has an egr valve. But if so need to get egr block off.
CAR: 2008 f250 6fo
BATTS: 2 100ah
SUBS: 1 Hybrid 18
AMP: 1 Sundown SAZ3000s
Old 07-11-2011, 05:44 PM
0/11 sssssss23
turbo
manifold
exhaust
injectors
Fuel lines
+1 to this. Every thing listed above seems spot on. I am not too familiar with the tsx engine but make sure you dont get a turbo/tune that is going to be to much for the motor. You dont want to be rebuilding an engine cuz that will be mucho $. As tuning goes, you should bring it to a reputable tuning shop that knows what they are doing. I know the subarus have an ECU tuner call the Cobb Accessport which the tuner then uses that device to provide you a map and then you can always return the car back to the stock tune if you ever part out the car. I assuming that is what the AEM standalone device does?
Old 07-11-2011, 05:49 PM
GoodyearJason's Avatar
0/11 sssss1398
I've only used hellion turbo kits. Not sure if they do imports, but you can call john and ask what he recommends. He's the top guy in the country for turbo info
Kenwood KVT-514, Clarion EQS746, Singer Alts, Ampere Audio amps
Old 07-11-2011, 05:50 PM
0/11 sssssss22
cobb does not have anything for factory non turbo cars. other than that i have to agree with buying from well know companies. a new motor will cost more than doing it right the first time. good luck if you decide to do it
Old 07-11-2011, 05:52 PM
0/11 sssss6190
I just realized it is joey who posted this..
Get that kit and push at least 25psi. Please..
Old 07-11-2011, 06:01 PM
0/11 sssssss23
this tsx is pretty sick
YouTube - ‪ATLTSX 400whp Turbo Acura TSX - Import Alliance Track Lap‬‏
WTB: 4guage 4channel amp kit/kit components O.G. D-Wet Wanting to Buy (WTB) 3 04-13-2011 10:50 AM
got turbo GODHATESCIVICS Off Topic Chat 4 11-04-2010 10:14 AM
Turbo and manifold audiobahnfan Miscellaneous Stuff For Sale 2 04-01-2010 10:52 AM
astro van flip kit or complete lowering kit sound_around Wanting to Buy (WTB) 1 05-26-2009 09:33 AM
Turbo question 92K1500 General Automotive Chat 20 02-15-2009 09:33 AM
