Car running cold? Container for engine coolant(antifreeze)? - Car Audio Classifieds!
Old 08-27-2011, 09:05 AM
its_ray_ray's Avatar
OCD Member
0/11 sssss5696
Feedback Score: 23 reviews
Default Car running cold? Container for engine coolant(antifreeze)?
I need to flush my coolant system in my car and i need a container large enough to empty it out and keep what i flush out.
Anyone got a suggestion?
Car is a 99 mazda 626 2.0l
My car keeps running cold and i know i got some build up in there as it has released a lil bit from a hose.
I just change the thermostat in hopes that it was just sticking open. But my wife just drove it to work and she said it was running cold again.....
Anyone have any suggestions for a container large enough for the flush or possibly why it is running cold even with a brand new thermostat?
Sent from my IHO Powered LG-VM670
Old 08-27-2011, 09:27 AM
0/11 ssssss283
why do u need to keep old antifreeze??/ u dont antifreeze is only good for 5 yrs at MOST..and it cheap a gallon is 6 bux or so..
also if it was the thermostat sticking shut...car would get HOT.. thermostat stuck open..no big deal.. just take longer for car to warm up..and u would have no heat..
i bet money its a temp sensor issue
Old 08-27-2011, 09:33 AM
OCD Member
0/11 sssss5696
So i can dispose of it properly. I dont want that shit in my yard or driveway ya know.
Ill look into a temp sensor. My car shows cold then hot then cold. Mostly shows cold when using the a/c. Idk though
Old 08-27-2011, 09:38 AM
bikerdc17's Avatar
0/11 ssssss285
yeah dispose properly. your system is probably under 2 gallons so i would just use milk jugs. the trick is getting in the milk jug. if your car is running cold i would say either stuck thermostat (which you replaced), cooling fan on constantly(bad relay?), or your temp sensor is bad. best way to check that is to use a thermometer. that would verify that indeed your car is running cold
Old 08-27-2011, 09:44 AM
OCD Member
0/11 sssss5696
How would i do that?
Old 08-27-2011, 09:51 AM
bikerdc17's Avatar
0/11 ssssss285
make sure your car is cold, take the radiator cap off stick a thermometer into the coolant and let your car heat up. you will probably spill a little coolant though so you should be prepared for that. watch the thermometer. check the thermometer and check your cluster gauge. if your gauge is cold but the thermometer is around 160-190 then i would say you have an electrical issue with the temp sensor or wiring to the temp sensor. also if your cooling fan comes on right away when you start the car that would send me in a different direction. it is also possible that you may have installed the thermostat incorrectly or you could have a defective thermostat.
Old 08-27-2011, 10:03 AM
OCD Member
0/11 sssss5696
Ok ill check that later. And i replaced the thermostat exactly as the old one was.
Old 08-27-2011, 10:33 AM
reddude157's Avatar
0/11 ssssss191
there's about 4~5 gals of anti freeze in there so yeah four or five gallon jugs of some sort and running cold could be sensor more than the thermostat. get a cooking thermometer that will read the 160 to 190 a car should run at an all you need to do is attach it some how to right where the top hose is so you don't spill fluid every where.
hu kdc-hd942u amps zx650.4 & lanzar opti 1900d @ .5 ohms two 12" obsidians in [email protected] big3 200 amp alt oddy1750 up front oddy 2150 in back
Old 08-27-2011, 09:12 PM
OCD Member
0/11 sssss5696
So i have 2 fans right next to each other. 1 aimed at the radiator and 1 at the engine. At what point do these kick in and which would control what the gauge in the car would say?
Old 08-28-2011, 07:25 AM
OCD Member
0/11 sssss5696
Ok went to work at 630 left at 630 and drove down the interstate from athens to cleveland(45 min drive) in which most of the ride it said cold. So i pulled in the driveway and popped the hood real quick. And neither fan was running. Then after letting it sit for a couple minutes the fan on the right kicked on as it normally should. Im going to look into getting a thermo sensor. Just gotta locate it. LOL.
Is it true running your system in cold weather is bad? dadydolas General Car Audio Discussion & Questions 14 03-21-2011 06:15 AM
First Container of SA Woofers from Yesterday sundownz (Sundown Audio) 51 02-15-2011 05:48 PM
Voltage Drop- Just Car Running brandonb1029 General Car Audio Discussion & Questions 7 09-18-2010 03:29 PM
Battery dies while car is running? taylorpro General Car Audio Discussion & Questions 19 09-07-2010 03:36 AM
Car audio and cold weather???? heavyswimmer General Car Audio Discussion & Questions 17 12-08-2009 10:59 AM
