I hate vacuum - Car Audio Classifieds!
Old 05-02-2009, 06:40 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Default I hate vacuum
Like the title says I hate everything operated by vacuum. It is the most retarded thing ever.
http://s12.photobucket.com/albums/a2...t=MOV-0022.flv
http://s12.photobucket.com/albums/a2...t=MOV-0023.flv
How can I fix this? I like cruise control, but I hate that it surges. It didn't used to do it that bad.
Then just a vid of it idleing. It has massive bass, look at the bottle moving in the cup holder. Vid didn't pick up the seat. And I had to lower the quality to send it via media message.
http://s12.photobucket.com/albums/a2...t=MOV-0024.flv
Team CACO Team SHOK
Supporting Member
Old 05-02-2009, 07:05 PM
No, I'm not dead
0/11 sssss8128
Find the vacuum leak that's causing the fluctuations to your cruise control brain and fix it. A cracked hose can cause that.
Old 05-02-2009, 07:19 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Well I don't think it is a leak cuz the speedo does that sometimes without the cruise on. It is a cable speedo so why would it jump like that?
Team CACO Team SHOK
Supporting Member
Old 05-02-2009, 07:39 PM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
grease the cable.
Old 05-02-2009, 07:45 PM
No, I'm not dead
0/11 sssss8128
Yep, that's why your cruise is surging.
Old 05-02-2009, 07:51 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Ok, so what is the best way to grease the cable? I'm new to some of this older technology. In tech they trained us for all the new stuff, which I already new most of. Then when I worked as a mechanic they had me working with the electrical diag guy so I did basically nothing but OBD2 work because they were wanting me to take his place when he retired, but me and the owner didn't get along very well so he made me an oil changer at the shop closer to my house then fired me.
Should I just take the cable out and spray some white lithium grease in one end and hang it up? Or like that lock ease graphite shit?
Team CACO Team SHOK
Supporting Member
Old 05-02-2009, 08:22 PM
No, I'm not dead
0/11 sssss8128
Pull the cables loose at both ends. One from the trans to the brain and one from the brain to the speedo. The cable will slide free from one end, often from the upper end, just pull the core loose, wipe it with a good solvent, dry it then coat with a good grease and slide it back into the cable sheath. After both are done just reattach the ends.
Old 05-02-2009, 08:26 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
I think there is only 1 cable to the speedo, and then the cruise goes off the pedal, but there might be a computer I would have to look.
And what would you consider a good grease? Just the same stuff you put in wheel bearings or ball joints, or like white lithium, or silicone spray? I have a bunch of different things available to me for free.
Team CACO Team SHOK
Supporting Member
Old 05-02-2009, 08:31 PM
No, I'm not dead
0/11 sssss8128
I'd use wheel bearing grease. Lithium gets gummy after a while and silicone spray only leaves a thin film.
Old 05-02-2009, 08:49 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
okie dokey. I'll put some in a zip lock inside another zip lock and take it home with me.
Team CACO Team SHOK
Supporting Member
Gelhard GXV400VT Vacuum Tube Amp Biggy 2-Channel Amplifiers 7 02-23-2009 02:31 PM
Anyone else HATE their job? Snwbrdr1 Off Topic Chat 33 02-16-2009 04:32 PM
I hate my job 92K1500 Off Topic Chat 9 12-28-2008 02:38 PM
i hate these but bones22 General Car Audio Discussion & Questions 16 10-01-2008 08:34 PM
