95 suburban 5.7 350tbi engine code 32-map sensor. help... - Car Audio Classifieds!
Old 09-13-2011, 09:00 AM
0/11 sssss1053
Default 95 suburban 5.7 350tbi engine code 32-map sensor. help...
o.k so i just got done rebuilding the top ends with new heads n all,
truck was running perfectly fine. i then took it out yesterday on a highway run about an hour away to my cousins house and my check engine light came on.. i pulled over at gas station, turned truck off, turned it back on and the light was off and never came back on.
today i pulled the code and got ,
code 32
  • BARO sensor circuit(carb models)
  • EGR circuit(injected models)
  • MAP sensor(open)
now i need help as im not sure what these codes means or where the map sensor is. i have the throttle body injected 5.7 350.
where do i start to look ?
[SIGPIC] 4 15'' modded juggernauts with aluminum voice coils.. juggernauts will do 4000 rms per sub...and im swapping my 2 kicker 2500.1 amps, for a stetsom 10kd.. the rest of my system is ... 2 kicker 650.4 amps, 4 10'' evm dl10x mids. 4 8'' beyma highs. kicker kx3 3 way crossover, alpine old school digital sound field processor, over 100 feet of 0 awg flex wire and 300 amp iraggi alt, 4 deka intimidator batts...
Old 09-13-2011, 09:49 AM
BeeJay124's Avatar
BASSHEAD
0/11 ssssss117
i have a 97, so its a lil different. But i remember i had to replace that sensor before. If i recall correctly mine plugs into the my air intake (between the air fliter housing and the throttle body). It was literally just kinda like a plug-in type sensor.
97 GMC Suburban (daily driver)
New Build in Progress:
6 Sundown ZV3 18's in a BHE designed 4th order
10+ Sundown NeoPro 6.5
Will be running Mechman and XS Power
Rest is Undecided
Old 09-13-2011, 10:23 AM
loudcivic's Avatar
TEAM SHOK
0/11 ssssss922
start it up and unplug the sensor and see if it starts running rough cuz it should make it run different with it unplugged. then plug it back it and see if it idles better.
kenwood kdc-x595
IA DP 18's
TEAM SHOK 3.5K
mb quart onx 4.125
AB sq6b's | rf t1 power comps
stinger spv70's | SHOK wiring
Old 09-18-2011, 01:16 PM
0/11 ssssss226
If it went on and now it's off, it's the EGR. Don't worry about it.
It's pretty much the only sensor that will allow the SES light to actually turn off because it isn't critical to the actual operation of the engine.
eBay Username -
Old 11-18-2011, 08:35 AM
0/11 sssss1053
but would it give me poor acceleration ? ( a bad egr valvle ) even tho the light went back off.?
Old 11-19-2011, 05:58 PM
0/11 ssssss226
Well. You didn't mention that earlier. The MAP sensor is located, mounted on the intake manifold. Looks like this.
Duralast/MAP Sensor (SU105) | 1995 Chevrolet Tahoe 4WD 8 Cylinders K 5.7L TBI | AutoZone.com
First thing you'll wanna do is make sure the vacuum hose is hooked to it. If it is hooked up, try replacing try replacing the sensor.
FYI, If the truck runs better with the SES light on then it's going into "Limp home" mode, and it will run better. It defaults to a generalized fuel map and timing table, bypasses the O2 sensor, EGR and MAP sensor. Basically it's PE mode all the time.
eBay Username -
ac delco afs-75 o2 sensor new stills Miscellaneous Stuff For Sale 0 05-11-2011 03:26 PM
SUG: Community Map BassikInstincts Announcements - Suggestions - Feedback - Support 4 04-20-2011 07:34 PM
Pressure Sensor MopaRBumpiN General Car Audio Discussion & Questions 25 01-25-2010 05:51 PM
Sundown MAP Price Reductions! sundownz (Sundown Audio) 3 08-14-2009 04:02 PM
Add your name to the team map Patrick Simmons Team CACO 35 01-10-2009 08:59 AM
