advanced electrical question on a/c electrical wire fatigue - Car Audio Classifieds!
Old 12-01-2011, 09:55 PM
slowpoke's Avatar
newbie forever
0/11 sssss1160
Default advanced electrical question on a/c electrical wire fatigue
as it is known by i hope nearly everyone on this forum, wattage sent to your speakers is in the form of a/c(alternating current). now unlike d/c(direct current) power over distance for d/c results in loose of power and the equipment intended purpose efficiency is decreased. now with a/c its a little more demanding. if for example you place a 7amp saw on a 25ft 16gauge extension cord chances are the saw and cord is going to be fine. but now take that very same saw and place it on 300ft of 16gauge extension cord and likely the cord is going to burn up and possibly the saw.
now picture your speaker as being a saw with duel electric hook ups(example for duel voice coil). hooking it up in parallel has an effect of amperage required to propel the speaker. series requires current over distance. now that being said say i hook up 3 speakers all duel voice coil parallel onto them selves and then series line the speakers. all speakers requiring 1000watts. by theory wouldnt that show a 3000watt electrical fatigue on the voice coil wires since like with the extension cord its then using the coils to complete the circuit making it a longer distance of wire used at an alternating current to compete the circuit?
Old 12-01-2011, 09:58 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Umm... say what now?
First, you can't series 3 speakers.
Second (and more importantly)... zip it. Wire that shit up and get to wangin.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 12-01-2011, 10:08 PM
slowpoke's Avatar
newbie forever
0/11 sssss1160
amp-___-speaker speaker+___-speaker speaker+___-speaker speaker+___+amp
if i cant do that then how is it i can do that. i have done it. many before me and many after me have and will do that.
Old 12-01-2011, 10:17 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Ok. Lol. Let me rephrase... I have never seriesed 3 speakers Probably because I have never had the need to.
I guess that works. Good luck. Maybe someone who isn't an idiot will respond.
4x world champ
- Floyd E. Toole
Old 12-01-2011, 10:23 PM
0/11 ssss31256
The analogies you are trying to compare are not comparable.
The series load of the three equates a higher resistance... which "asks for" less power from the amplifier.
The difference in your analogies is that with the saw and cord, the load stayed the same but the distance was increased which is why the cord could not convey the energy because the cord itself became a load.
Each length of wire has a resistance but if the wire can convey the energy then the resistance is zero which means 100% conductivity.[for the distance]
So, anyway...
The series coils present a higher resistance which is less of a load to the amplifier.. and if your wire is sufficient to convey the energy, it is not part of the load.
Old 12-01-2011, 10:24 PM
Me > Lord Van
0/11 sssss2831
I'm not exactly sure what point you are trying to make here because your sentence structure and clarity is absolutely terrible, but I'll try and make sense of it.
Yes, when you series a voice coil (and in your case multiple subs) you are turning the windings into one giant strand of copper that will see the entire amperage load.
I think the point being made here is that wiring your subs in series rather than parallel can reduce power handling since the wattage is not being split between separate windings, rather it is going through one longer (and thus has lower amperage capacity) winding.
But what must also be taken into consideration is that when you wire a sub in series you also change the T/S parameters of the sub. Wiring a subs coils in series will not necessarily make the sub handle less power.
Team DOA
10 inches of terror
One DD 9510F + one kicker zx2500=150+ db
One Sundown SA-8 + 2 mb quart 2000's = 150+ db
-2006, 2007, 2009, and 2010 MECA World Champion
-2008 Bassrace 130-139.9 National Champion
The Following User Says Thank You to tommyk90 For This Useful Post:
terra (12-01-2011)
Old 12-01-2011, 10:26 PM
Me > Lord Van
0/11 sssss2831
So, anyway...
To play devils advocate here, he could say that two different impedance subs are used which will equal the same final load, but one is wired in series and the other is wired in parallel.
In which case the length will make a difference, but there's still other variables involved in that one. Coil WW, winding diameter, winding material, etc.
Frankly I don't know what the point of this thread was, I was just trying to clarify what the OP was saying. Not sure if it was worth the effort.
Team DOA
10 inches of terror
mega fatty
0/11 sssss6008
that cord would be a much larger load for being 300ft being a regular extention cord rather than say 50ft. so to get the power you need to run the saw it will have to work that much harder.
a voice coil, is an inductor so its not the same as a 300ft run of wire. it would only experience loose through the speaker wire, and into the coil, after that it will have impedance gain making you loose power
do not worry about it for your speakers
07 mazdaspeed3
rd d9 @ .5ohm
slowpoke's Avatar
newbie forever
0/11 sssss1160
i think you do see what im attempting to explain/ask. yes im concerned about the coils then acting like a longer piece of wire and still handling the higher wattage wandering if that can cause failure of the coil/coils
Old 12-01-2011, 10:31 PM
slowpoke's Avatar
newbie forever
0/11 sssss1160
and at that the only reason i ask is the new hdc3 that i just got has a coil wire strand half the diameter as my hdc3 that i already had. now since these are in single chamber enclosures im not to concerned with the speakers effecting each other but more so how will the electrical load see this being 2 very different coils(yet the same ohms) if then having to work together in a series circuit.
also i am partially dyslexic which makes it difficult at times to explain what im actually thinking. sorry ill attempt to word things better in the future.
Another electrical question for DC 5K @ .5 jhg33k General Car Audio Discussion & Questions 12 11-08-2011 04:27 PM
Should I(electrical question) LyferXB9s General Car Audio Discussion & Questions 27 06-06-2011 05:22 PM
another electrical question Memphistahoe02 General Car Audio Discussion & Questions 23 02-02-2010 08:36 PM
Another Electrical Question crownvicon26's General Car Audio Discussion & Questions 11 01-22-2010 11:55 AM
electrical question korey_hofer General Car Audio Discussion & Questions 10 02-04-2009 08:40 PM
