Enough amperage/ wiring help - Car Audio Classifieds!
Old 12-01-2011, 10:35 PM
0/11 sssssss17
Default Enough amperage/ wiring help
I have a rockford t1500 bdcp amp and a t 600-4. I need to upgrade my alternator I was just curious as to how many amps I'd need to cover the load? I also have a shuriken bt-120 battery if that matters at all. Also curious as to whether or not id have to buy an upgraded wiring harness or if my stock one would suffice?
Old 12-01-2011, 10:47 PM
0/11 ssssss288
Stock wire harness is fine. Read up on the big 3, remembering that you only add a few wires and don't remove any.
~ 150amps of draw from those amps is what you want to be prepared for, the more the merrier though since that doesn't count general electrical consumption by your car itself
Need box help? Pm surreal
Old 12-01-2011, 11:31 PM
0/11 sssssss17
I forgot about the big three thanks. I assume that my stock alternator is around 100 amps so would i need a 250 amp alt to make up for the demands of the amps or would something like a 180 amp alt work? I dont want my lights to dim when the bass hits and i dont want my voltage to drop in fear of ruining the amps from clipping.
Old 12-02-2011, 12:11 AM
0/11 ssssss288
I'm sure 180 is still plenty with a decent battery or two I'm sure you'd be golden.
Just don't underestimate the importance of good grounds
What amperage alt??? Shakindablock General Car Audio Discussion & Questions 6 09-05-2011 10:02 PM
wire amperage crownvicon26's General Car Audio Discussion & Questions 35 11-15-2009 08:48 PM
Excessive Amperage Antstar24 General Car Audio Discussion & Questions 29 07-15-2009 10:33 AM
finding the amperage Snwbrdr1 General Car Audio Discussion & Questions 23 02-21-2009 10:49 AM
Excessive Amperage? mazda6i07 General Car Audio Discussion & Questions 22 02-12-2009 10:47 AM
