Amplifier clipping lights correct? - Car Audio Classifieds!
Old 12-01-2011, 11:15 PM
0/11 sssssss59
Default Amplifier clipping lights correct?
Right now i'm running a Mb Quart Q1.1500d to 2 SA-15's (soon to be upgraded to a SAZ-2000d) and I was wondering if the clipping light was accurate on these amps? Because I read a thread about setting gains with a dmm and I have just used a 40HZ tone and the clipping light to set it until recently. I would turn the volume on my mp345u to 32/35 (i think it clips at 34) and set the gain up until the clip light would turn amber. However, in the thread it said to use a 50hz tone and set it to the sqrt of my power since i'm running at 1 ohm. I got that number and it was 38.7. So today I disconnected my speaker wire to the subs and hooked in my dmm, put on a 50hz tone and checked the voltage and it was only reading like 20.4 or something, but I noticed when I increased the gain to 38.7 the light for clipping came on around 22 volts. So my question is should I trust the dmm or the clipping light?
Old 12-01-2011, 11:21 PM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
iirc you need to keep the subs wired when using a DMM because the load will make the amplifier react differently and clip at different gain levels...
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
MB Quart Onyx 1500.1
/Surreal
Old 12-01-2011, 11:59 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
The load does not really change the clipping.....However, having a speaker hookedup can somehow alter where it clips a little. Like say your voltage in your electrical drops because of the load the sub is drawing is too much for the electrical....But this dosn't go to say that impedance causes a real variation in where it clips generally, that's bs.....clipping is due to voltage, not current/load.
Old 12-02-2011, 12:02 AM
0/11 sssssss59
Originally Posted by Novicaine View Post
The load does not really change the clipping.....However, having a speaker hookedup can somehow alter where it clips a little. Like say your voltage in your electrical drops because of the load the sub is drawing is too much for the electrical....But this dosn't go to say that impedance causes a real variation in where it clips, that's bs.....clipping is due to voltage, not current/load.
So doesn't clipping light coming on at 22 volts seem low for a 1500 amp? I'll test tomorrow with the subs plugged in.
Old 12-02-2011, 12:15 AM
0/11 ssssss855
i would say go by the clipping light the dmm is just a ball park of what the amp should be doing set the voltage with the dmm to what ever the chart says then hook your subs up and turn it down intill the light goes off..
i used to set the gains by dmm didnt seem loud to me i think i was doing it wrong then i went to the 3/4 theories then i got a dd-1 and thats how i set my gains now
The Following User Says Thank You to lilsoccersully For This Useful Post:
Novicaine (12-02-2011)
Old 12-02-2011, 07:29 AM
0/11 sssssss59
let me borrow your dd-1 cant afford that $150 man
Old 12-02-2011, 12:45 PM
0/11 ssssss855
LOL I might be going to Houston soon with in a week but I'm not sure yet and if i do I'll bring it with me
Old 12-02-2011, 05:28 PM
Novicaine's Avatar
0/11 sssss6135
I'd also agree that the DMM is just a ballpark...It IS infact a guess because you aren't going really know where the amp clips at by putting it to the "rated output", we all know some amps are overrated, some under.
Anyway, as to the question: Dosn't 22v seem too low for 1500watts? I have NO idea. All amps are different. If you want to be sure then try an o-scope or that DD1 thing.
Old 12-02-2011, 06:48 PM
0/11 sssssss59
I'm probably just gunna ahead and get the dso nano because I've seen the difference a little gain can make.
Old 12-02-2011, 06:52 PM
Novicaine's Avatar
0/11 sssss6135
I ordered one myself but the damn thing hasn't came for about a month so far....I think it gets here from overseas and should be here in maybe a week .....Make sure to order from inside the US.
does this look correct? knockinthastreetzof608 General Car Audio Discussion & Questions 12 04-10-2011 01:19 PM
Just making sure this is correct? jrplayer36 General Car Audio Discussion & Questions 0 12-15-2010 10:00 PM
Is this Correct? beany General Car Audio Discussion & Questions 26 11-01-2010 08:33 PM
Is my box correct? crownvicon26's General Car Audio Discussion & Questions 37 11-01-2010 08:27 AM
Need an amp, need your help to find a correct one. Bologna General Car Audio Discussion & Questions 3 04-27-2009 08:52 PM
