alternator setup questions. - Car Audio Classifieds!
Old 12-02-2011, 02:55 PM
regizzle's Avatar
0/11 sssss1427
Default alternator setup questions.
currently got my 250 amp alternator from mechman last night, installing it today. should i fuse the line? and i should use a 250 amp fuse if i do right? and does the anl fuse box have to be waterproof? Its a 1996 chevy tahoe so the alternator isnt close to the ground so i dont really think theres a chance it'll get wet but yea...
Also, my altertnator has a ground post on it, Where should i put the ground? Same place i have my engine block to frame ground? (already have big 3.)
Old 12-02-2011, 08:01 PM
0/11 ssssss459
Most people ground everything in their system to the same spot, In my friends truck I grounded the negative post to the battery and made sure I had a very good battery ground.
Oh, and the line in his truck isn't fused, it's up to you though, I would fuse it if you even have the slightest idea or thought that it could get cut or wet.
Old 12-03-2011, 11:32 AM
0/11 sssssss90
Generally we do not fuse the alternator cable because it is so short and direct, but you can fuse it if you want. The fuseholder does not have to be waterproof, as long as your cable is sealed with heat shrink so that it cannot corode.
Ground cable should run from ground stud on alternator to negative terminal of the battery.
Old 12-03-2011, 08:30 PM
regizzle's Avatar
0/11 sssss1427
i have the 0 gauge wired up and the original wiring both to the alternator, should i forgo the 6 or 8 gauge.. not sure what it is.. or leave them both on.
Old 12-05-2011, 08:30 AM
MECHMAN's Avatar
0/11 sssss1142
Leave your OEM wiring, add the 1/0 cable in addition to that wiring.
The alternator should be grounded from the provided stud directly to the battery negative post for the best performance.
For the charge cable, you can fuse if you like, some do, some don't. If you fuse it I would recommend 300a and carry a spare, the heat under the hood combined with the sustained current from the alternator can cause fuse failure in extreme circumstances.
Old 12-05-2011, 12:18 PM
regizzle's Avatar
0/11 sssss1427
k, gotta get that negative bolt done today. tty
Old 12-05-2011, 12:42 PM
MECHMAN's Avatar
0/11 sssss1142
Have fun with it!
Old 12-05-2011, 03:25 PM
regizzle's Avatar
0/11 sssss1427
Yep! currently wired to 2 15" JBL 300 rms each but my amp is an autotek mm2000.1d (old version) so that sucker eats current like a lesbi4n eating... yea. haha, barely ever any voltage drop at idle, if any maybe a .1 drop for about a second on initial hit, Very very happy with the alternator. Just need to buy the AVM to bring it up to 14.8 vs the 14.2 set point im currently at. and install my lvl 4 18
some sq setup questions? Foxs87s10! Sound Quality Area 10 09-11-2011 10:15 PM
alternator help and questions? mrtopnotch561 General Car Audio Discussion & Questions 6 06-04-2011 10:27 PM
my setup questions big d General Car Audio Discussion & Questions 0 01-02-2011 07:55 PM
New subs ,New setup, New questions!!! larry General Car Audio Discussion & Questions 10 04-01-2010 08:58 PM
alternator questions Antstar24 General Car Audio Discussion & Questions 20 07-09-2009 01:02 PM
