question about passive radiators - Car Audio Classifieds!
Old 12-02-2011, 08:32 PM
0/11 sssssss31
Default question about passive radiators
ok so im thinking about what to do for next summer im thinking of doing 2 oa 18s when they come out in about 4.5 cubes sealed with passive radiators but i have no idea how many i would use or what size, could i get away with 1 18'' pr per powered 18 each 18 would be in its own box and each box would be roughly 19x34x15 and in the trunk of an 05 impala any thoughts on how this might work or fail ?
05 impala
rockford t20001bd
HDC318 copper
Old 12-02-2011, 08:50 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
id choose other options. there is many simpler, less expensive, more appropriate designs for the trunk of an impala. i wouldnt use 15's in a trunk. let alone an 18. let alone 2. i think you'd be better off trying a more conventional setup. however, if you really wanna pursue this, i think physical space will end up being your enemy as an 18, and then an 18" PR makes 36" one direction, which is likely wider than most sides of the trunk. you can likely get away with one pr since its a lower power driver, but i cannot point you in whiich direction to go from here
-Youtube Channel
Old 12-02-2011, 08:59 PM
Wingman0121's Avatar
0/11 sssss2171
I would say two 18 inch passive radiators per a single 18. The passive radiator should have equal or greater excursion and get the ones with a screw thread so you can adjust the weight of the cone to "tune" it. The heavier the cone the lower the tuning but you also lose SPL so you just have to find a good tradeoff between low end extension and SPL.
Old 12-03-2011, 02:57 PM
0/11 sssssss31
im really just looking for new ideas i thought it would be diffrent, right now im running an 18'' hdc3 in about 5 cubes iirc. ive ran 10s and 12s and wasnt really happy with the output. i have a couple sa-15s that i havent got around to building boxes for yet. out of curiousity why are you against large speakers in trunks?
i was looking at psi passive radiatiators but i may have to abandon this idea if i will need 2 18'' prs i really dont have the space for that i was just looking to do something diffrent, im not looking to get metered i like my lows lol
05 impala
rockford t20001bd
HDC318 copper
How effective are passive radiators? maverickdog8 General Car Audio Discussion & Questions 20 12-05-2010 02:42 PM
2x 10" Passive Radiators grimreper912003 Speaker Accessories & Parts 12 09-12-2010 12:20 PM
Anyone interested in Passive Radiators?! TeamPSI (PSI Car Audio) 253 05-23-2010 12:16 PM
15" Passive Radiators scottiej Speaker Accessories & Parts 2 11-30-2009 10:39 PM
Passive Radiators: The Basics madmat Tutorials & Quick References 0 10-28-2009 07:22 PM
