remote doesnt work on amp - Car Audio Classifieds!
Old 12-02-2011, 10:14 PM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
Feedback Score: 38 reviews
Default remote doesnt work on amp
ok i got a amp that works perfect other than 1 small problem,the remote.Something internaly is messed up.The remote doesnt work and i have it hooked up right.I have my remote going to a fuse tap and i just tap into my HU fuse,that has always worked just fine.(amp comes on without a remote)I did some research and ppl said it has a bad pwm chip(pulse width modulator) The only way i can get it to shut off is pull my inline fuse,if not it will stay on no matter what.I already know you can hook a toggle switch to amps using the remote but it doesnt work and that wouldnt matter,is it possible to use a toggle switch to turn it on and off how it is not having a remote input that works?
refs:
Old 12-02-2011, 11:21 PM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
bummpp
refs:
Old 12-03-2011, 08:13 AM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
the amp turns on with just positive battery and ground negative attached and no remote wire hooked up?
TeamGG
Team D.O.A.
Old 12-03-2011, 08:16 AM
sableflexn's Avatar
0/11 ssssss872
that would be the first time ive heard of that lol
2x TSNS 18
**AB 1100.1 COMING SOON
2x xs d3100 3 MORE SOON
1x xs d3400
17 cube wall @ 38 hz CHANGING TO 28 SOON
Old 12-03-2011, 09:08 AM
0/11 ssssss149
what model amp is this....ive had older amps that use relay that the relay has fused together.......any gut shots?
Old 12-03-2011, 03:36 PM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
yes,its a d3 600.1 and it works without a remote plugged in...I can pull out the remote and it still doesnt shut off,only way i can get it to shut off is pull the inline fuse.This is the first time this has ever happened to me,and iv never heard of a amp doin this before either.
refs:
Old 12-03-2011, 03:49 PM
Prohibited Sellers/Buyers
0/11 sssss1770
got a gut shot?. this a common issue on some amps.
Old 12-03-2011, 03:51 PM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
ill post some in a few
refs:
Old 12-03-2011, 04:20 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
hey joe you can wire a remote to the power wires,
im just spit ballin here,
but if you could find a large enuff relay that can handle the amperage your amp is pulling, just wire the low voltage side off your ign. switch an it should power on/off just like a normal, small 30 amp relay, rite
thats if the internal problem cant be fixxed,
Old 12-03-2011, 06:08 PM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
idk,maybe if i could find a wiring diagram for a relay..lol never hooked a relay to anything but i can get one if i have to cheap,prolly 5 bucks.
refs:
thiz doesnt exist... upzaw2000 Team CACO 7 09-27-2011 04:27 PM
Whose brain doesnt hurt tonight? I need it. 3rdshiftdiscretion Enclosure Discussion & Design Construction Help 18 07-19-2011 11:14 PM
what doesnt DC make? 2000LaDe Off Topic Chat 5 02-25-2011 11:49 PM
SELL-TRADE..BASS/GAIN remote & cord only....SAZ-1500D...NO AMP! CodyBrown2013 Car Audio Trader (WTT) 2 02-14-2011 10:48 PM
why doesnt my amp work unless hooked up in master to another in slave numba1system General Car Audio Discussion & Questions 2 01-07-2010 01:01 AM
