crown vic kick panels? - Car Audio Classifieds!
Old 12-03-2011, 01:45 AM
MERQUE's Avatar
0/11 ssssss622
Default crown vic kick panels?
i want to add another set of 6.5 comps in my crown vic but i have not seen any kick panels for crown vics? do they make any? i already have a set in the front doors and rear deck. i want to add another set.
Old 12-03-2011, 01:48 AM
MERQUE's Avatar
0/11 ssssss622
the reason for this is i want to make sure i have enough treble for my new setup and i dont want all my bass to drown out the music. i was also thinking about adding 4 extra tweeters?
Old 12-03-2011, 01:51 AM
0/11 ssssss133
adding in tweeters will not help you with the problem you are talking about. If you have good front and rear speakers you wont need anything else (other than maybe an amp for them) unless you plan on walling the car off.
Old 12-03-2011, 01:55 AM
MERQUE's Avatar
0/11 ssssss622
why not? will tweeters help at all?
Old 12-03-2011, 02:33 AM
MR. YOGI's Avatar
0/11 ssssss255
Default kicks
What year model is your crown vic? I have a 2001 grand marquis(same car) and i looked for them as well. They don't make them most likely due to the parking brake. The only solution would be custom made ones that will most likely eliminate the parking brake. Hope I helped a bit.
Pioneer Head Unit (for now)
EA 300a Alt
4 Crossfire XSv2 15s on 2 Crossfire XS-8K's
16 Crossfire XS-M6 on DD S2b
4 Crossfire XS-ST1
Old 12-03-2011, 07:00 AM
MERQUE's Avatar
0/11 ssssss622
i have a 2000
Old 12-03-2011, 07:01 AM
MERQUE's Avatar
0/11 ssssss622
are mids the only way to go?
Old 12-03-2011, 10:32 AM
MR. YOGI's Avatar
0/11 ssssss255
Default kicks
Yeah 1998-2003 are exactly the same. Best bet is going custom. They can probably work around the parking brake pedal but since they get angled you won't be able to apply the e-brake.
EA 300a Alt
4 Crossfire XS-ST1
Old 12-03-2011, 10:53 AM
0/11 sssss3842
yep the parking break is a problem for alot of vehicles. best bet is to glass the doors to fit what you want.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
97 crown vic idontcarehoe Build Logs 2 04-20-2011 12:13 AM
97 crown vic idontcarehoe General Automotive Chat 10 01-05-2011 09:55 AM
Get louder with 01 crown vic?? Racerkid15 General Car Audio Discussion & Questions 14 11-29-2010 12:06 AM
Electrical for a 04 Crown Vic help? tez4life General Car Audio Discussion & Questions 4 02-25-2010 01:15 AM
Crown vic owners grimreper912003 General Automotive Chat 0 11-02-2009 12:01 AM
