second battery in trunk for daily. 4KW. - Car Audio Classifieds!
Old 12-03-2011, 09:22 AM
MERQUE's Avatar
0/11 ssssss622
Default second battery in trunk for daily. 4KW.
when wiring a second battery in trunk next to amps how should i wire them both up? i plan on one +/- 0 gauge run from front battery to trunk battery, alt + is going to front battery, then grounding the battery in the trunk also? then amps directly to battery?
Old 12-03-2011, 09:28 AM
0/11 sssssss55
I usually have it like that..
Alt+>front batt>power wire ran to the back>trunk battery>amp
Old 12-03-2011, 09:31 AM
0/11 ssssss452
sounds you've got it.. Run the front and rear batts in parallel.. Ground in trunk.. amp to the rear batt..
Old 12-03-2011, 09:38 AM
Loud Lynny's Avatar
0/11 ssssss116
sorry wrong thread
Old 12-03-2011, 09:49 AM
0/11 ssssss759
Is a fuse needed between the two batteries?
2000 Astro on 20s - Kenwood X595, Audiocontrol Three.1, JL Audio 10W7, Audiopipe APSM-1500, Hifonics Titan TXI6408, Powerbass 4XL 6.5" Mids, DB Drive S3 T1 Tweeters, Optima Yellow Top, Shuriken BT-60
Old 12-03-2011, 12:59 PM
MERQUE's Avatar
0/11 ssssss622
i dont think its needed but i know its recommended.
Old 12-03-2011, 01:00 PM
0/11 sssssss59
2 fuses unless you want your car on fire
Old 12-03-2011, 01:10 PM
MERQUE's Avatar
0/11 ssssss622
you mean just in case the power wire going from the front battery to the back battery shorts?
Old 12-03-2011, 01:15 PM
JMoney18's Avatar
0/11 sssss1577
just run your wires safely n you'll be finek but yeah fuse your power wire if that's what your asking..
Old 12-03-2011, 01:22 PM
gti1.8t's Avatar
0/11 ssssss361
sorry to thread jack....
I have 2 Kinetik HC2400's & 1 HC2000 (since this is all I can fit, I can't squeeze in another 2400).
In which order should I wire them? Should the 2000 go in the middle of the bank or at the end?
best way to ground battery on trunk with unibody ? michigancapri92 General Car Audio Discussion & Questions 9 02-12-2011 09:08 PM
Sub/port up in a trunk: does it work for daily? 1ndatrunk Enclosure Discussion & Design Construction Help 11 08-17-2010 10:04 AM
Adding second battery in trunk KAPONE.SS General Car Audio Discussion & Questions 9 05-16-2010 12:42 PM
Wanted : Tutorial on doing Big Three when battery is in trunk NOFATTYS Tutorials & Quick References 2 04-17-2009 09:17 AM
Subs that can handle 4kw+ daily? RE_Gawker General Car Audio Discussion & Questions 47 11-18-2008 07:17 PM
