Smaller Dimension Batteries? - Car Audio Classifieds!
Old 12-03-2011, 10:13 AM
0/11 ssssss639
Default Smaller Dimension Batteries?
I've got very little trunk space left but would like to drop an extra battery or two in. Are there some smaller sized batteries that would be cheaper but still perform well? I will measure my space in a few days once the box goes in. I just know it will be very little.
Old 12-03-2011, 11:26 AM
chapdawg1971's Avatar
Semi-Loud Trunk
0/11 sssss1950
Feedback Score: 25 reviews
What are your requirements? What does your system consist of? I have an Optima yellow top up front of my truck and a Kinetik 800 under the back seat and have a little over 2k and have zero issues.
I am here: Google Maps
4th USACI WF 2011 Trunk 0-1K 154.3db
157.??....and done.
Old 12-03-2011, 01:33 PM
newarkbeast973's Avatar
0/11 sssss7810
Yea. Need to know how much power your running, and final load of your sub(s)
Stock alt? How many AH is your alt? What battery is under the hood? How hard do you bump your system?
New build coming soon!!
Old 12-04-2011, 12:38 AM
0/11 ssssss639
I should be running between 1500 and 2.5k or less. 2.5 k is pushing it though. Probably overall around 2k.
as for dimensions, like i said I'm not sure. My box has to be assembled in the trunk, and until then i wont know.
I have a stock alt that i believe is a 110 amp. wussy little focus. Stock battery up front. Probably upgrade that first?
Old 12-04-2011, 12:50 AM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
Start off with the biggest battery you can fit up front and make sure to do the Big 3.
You could get two XS D975 batteries and put one under each seat if the will fit and not even have to worry about trunk space...
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
MB Quart Onyx 1500.1
/Surreal
Old 12-04-2011, 01:56 AM
0/11 ssssss639
I have the big 3 done. Its been done for a while, too. If all goes well, I will be running a stetsom ST600.4 and a Cerwin Vega Stroker 2k. But neither of the people replied :[
I guess i should look at batteries before i blow a ton on amps.
Old 12-04-2011, 08:30 AM
Semi-Loud Trunk
0/11 sssss1950
Yep, start with the largest up front and go from there. I posted what I have on a little over 2K. Stock Nissan Titan alternator as well. Oh, and it's a smaller yellow top also.
157.??....and done.
Old 12-04-2011, 09:32 AM
0/11 sssss7810
Like stated before, get the biggest battery up front. If you can afford it get a d1200 from xs. That's a little power house battery!! I had a d1200 and d975 holding me down for 3k rms with no light dimming at all!!
What would be the missing dimension on this box?? newarkbeast973 Enclosure Discussion & Design Construction Help 7 11-14-2011 08:25 PM
WTB: U-Dimension Forte 20VS amplifier Jupazuba Wanting to Buy (WTB) 0 05-30-2011 08:02 AM
Let's talk smaller then 8s joejohanson.. General Car Audio Discussion & Questions 25 05-19-2011 05:37 PM
6 spoke 18" sub cutout dimension? da box king General Car Audio Discussion & Questions 12 05-06-2010 04:28 PM
Mixing wet batteries, and Dry batteries. hornedfrog1985 General Car Audio Discussion & Questions 0 09-22-2009 08:49 PM
