How much can a JL Audio 13.5w7 handle? - Car Audio Classifieds!
Old 12-03-2011, 11:10 PM
0/11 ssssss189
Default How much can a JL Audio 13.5w7 handle?
What can the 13.5w7 put out wattage wise?
should i do bigger than a JL 1000/1?
Old 12-03-2011, 11:23 PM
Wheres The Butta's Avatar
0/11 sssss6101
Feedback Score: 21 reviews
1000 watts for the older ones, 1500 supposedly for the AE.
I'd just go with the 1000/1 because of the ohm config on the 13.5
also, subs don't "put out" power, they "handle" it.
____________________________________
IASCA Pro AM and MECA Modex -->
The Following User Says Thank You to Wheres The Butta For This Useful Post:
two8w7 (12-03-2011)
Old 12-03-2011, 11:58 PM
ascitiesburn69's Avatar
0/11 sssss1645
Not enough....
Team S.P.E.A.D.
Trunks FTW
Old 12-04-2011, 12:15 PM
0/11 sssss1181
My buddy ran 4 of them with a circa 2006 MTX 1501D on each one and it was pretty mean in a Ford Expedition
Old 12-04-2011, 01:19 PM
0/11 ssssss231
I remember when Pete (PWK) had his truck and ran a Colossus each on two. It was nice!
Old 12-04-2011, 01:47 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
only differance between the AE and the regular 13w7 is cosmetics. I have a 13w7AE and a Jl 1000/1 and i know that i can run the 13w7AE on my Jl 1000/1 freeair full power with no ill effects (testing purposes only). in a ported box built to spec will take around 1500rms, sealed will take a little more
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 12-04-2011, 05:09 PM
0/11 sssss1217
Feedback Score: 40 reviews
Just look at the 13w7 manual - I think it says the power handling range is 500-1500 rms & anything over 1500 rms voids the warranty. But the overall consensus is 1000 rms only because that amount of power was the largest size amp jl produced before the hd1200/1. Obviously jl knew what they were doing with that d1.5 voice coil configuration (good luck trying to find an amp that puts out that specific power at 0.5 or 3 ohm other than a slash series amp at the time of the w7's initial release), but nowadays with all these underrated amps its pretty easy to find something to give the 13w7 sufficient power at 0.5 or 3 ohms. I had 1 and then 2 13w7's on a fosgate t20001bd and it pounded, so really whatever sounds good to you will be enough.
Refs -
and many more...
Old 02-27-2013, 11:17 PM
Brand New Members
0/11 ssssssss4
I had a customer with 4 hd750s on 2 13w7s ported in a tahoe. clamped a bit over 2k each , he ran it as a street beater for 2 years, never had one fail.
Old 02-28-2013, 12:03 AM
0/11 ssssss322
Ran mine with 1 JL 1000/1 on each coil for a while.
Upgraded to an Orion 2500D @ 0.75 ohm (Dual 1.5 in series is 0.75 not 0.5)
You can run them on any 1 ohm stable amp if you are careful. The 12's are the ones the ohm load limit your amp selection a lot!!
Old 02-28-2013, 12:09 AM
Dunbar91's Avatar
0/11 sssss6816
Feedback Score: 51 reviews
That sub was not made to take a beating or for spl. It has the rating for a reason, the sub is to get loud but sound great on the recommended rms range. I doubt that thing can take more than 1900rms in a daily app
RE SX 10s, what can they handle? MopaRBumpiN General Car Audio Discussion & Questions 11 10-15-2011 10:28 PM
18's that can handle 2.5k cdorton16 Wanting to Buy (WTB) 14 08-24-2011 01:28 PM
How do you handle this? Matt3824 Off Topic Chat 16 07-04-2011 12:28 PM
Could they handle 4k crownvicon26's General Car Audio Discussion & Questions 5 10-13-2010 01:19 PM
Sub that can handle 2krms JMPellman7 Wanting to Buy (WTB) 24 06-20-2010 08:55 AM
