bridging the 4x90 - Car Audio Classifieds!
Old 12-04-2011, 03:25 PM
badmofo529's Avatar
0/11 sssss3329
Default bridging the 4x90
i've been trying to bridge my 4x90 to give my comps some extra power, but not successfully. i have it hooked up with the driver side 1st ch + 2nd - and passenger side 3rd + 4th -. im only getting sound out of my driver side speaker. what am i doing wrong.
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 12-04-2011, 03:28 PM
MERQUE's Avatar
0/11 ssssss622
look at the manual
the bridge channel should be labeled
Old 12-04-2011, 03:30 PM
0/11 sssss2264
Feedback Score: 33 reviews
There may be a switch for 2 channel mode
Sent from my LG-MS910 using Tapatalk
pretty sure the lms coil just aids in some woogey boogy shitt called SQ
Whats prototype about an off the shelf design in an off the shelf casing?
Old 12-04-2011, 03:32 PM
badmofo529's Avatar
0/11 sssss3329
nope and nope lol. there is no labeling and the manual dosnt say how. there is no switch either
'97 chevy s10
-kenwood x994
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 12-04-2011, 06:11 PM
badmofo529's Avatar
0/11 sssss3329
bump. trying to get this figured out to nite
'97 chevy s10
-kenwood x994
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 12-04-2011, 06:14 PM
MERQUE's Avatar
0/11 ssssss622
do you have all the rca inputs going in? you should all four rca inputs on the amp plugged in.
Old 12-04-2011, 07:05 PM
badmofo529's Avatar
0/11 sssss3329
figured it out. the 2nd channel rca needs to go to the 3rd channel spot. but when its hooked up like this i get horrendous alt whine and noise. hooked it back up normal, no noise. why would it be doing this?
'97 chevy s10
-kenwood x994
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 12-04-2011, 07:10 PM
MERQUE's Avatar
0/11 ssssss622
its usually a bad amp ground or rca ground . an old pioneer i used to have had the bad rca ground, some pioneers are known for that .
Old 12-04-2011, 07:11 PM
badmofo529's Avatar
0/11 sssss3329
but there is no noise when its not hooked up like that. only when the 2nd ch rca is in the 3rd spot.
'97 chevy s10
-kenwood x994
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 12-04-2011, 07:14 PM
MERQUE's Avatar
0/11 ssssss622
bad rca inputs on amp?
Bridging help Demigod General Car Audio Discussion & Questions 15 07-23-2011 02:19 PM
Bridging Ground Poundin Jeff General Car Audio Discussion & Questions 5 07-21-2011 10:00 AM
bridging nutxo General Car Audio Discussion & Questions 1 07-07-2011 11:31 PM
aq 4x90 bridging cwruck General Car Audio Discussion & Questions 3 12-22-2010 06:54 PM
bridging 4 channel gbo559 General Car Audio Discussion & Questions 10 01-02-2010 01:15 AM
