Two amps, one remote knob? - Car Audio Classifieds!
Old 12-05-2011, 01:56 AM
0/11 ssssss617
Default Two amps, one remote knob?
For an experiment, I am running two matching sub amps, but I only want one remote knob. Has anyone tried running a cat 5 splitter, or something similar?
Old 12-05-2011, 02:14 AM
EARmeBump's Avatar
0/11 ssssss404
I am curious about this as well. I have (2) saz2500's but one bass knob
It was a water bed, 6x9s mounted to the head board and the deck running off a radio shack power supply to set the mood for the girls. Not that there we many but I did OK.
I was born in the dressing room at walmart. My mom was a door greeter, my father a cart cowboy. Times were tough, but I pushed on and became manager of electronics at the des moines Iowa walmart.
Old 12-05-2011, 02:27 AM
serjr711's Avatar
0/11 sssss2699
Feedback Score: 65 reviews
If you have 2 identical amps and they can be strapped, you can use one bass knob to control both amps. I believe you have to have a master and slave selector on both amps.
Old 12-05-2011, 02:28 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
A cat5 splitter wont do shit. Amps don't use cat5 connectors (that I've seen)
Team CACO Team SHOK
Supporting Member
Old 12-05-2011, 06:46 AM
0/11 ssssss855
Last I checked don't they use standard phone line cable type stuff and why no strap the amps so that way you have the exact same settings as the master amp
Sent from my PG86100 using Tapatalk
Old 12-05-2011, 07:17 AM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
Maybe his amps can't be strapped in a master/slave config. I plan on getting a second MB Quart Onyx 1500.1 which can't be strapped but gain matching them and would like to know if I could use one bass knob for both of them also.
Also my Onyx for sure uses a Cat5 connector though my friends Audiopipe amp used a telephone connector...
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
/Surreal
Old 12-05-2011, 07:18 AM
chapdawg1971's Avatar
Semi-Loud Trunk
0/11 sssss1950
Feedback Score: 25 reviews
I believe you would have to have your amps gain matched, even if it were possible.
4th USACI WF 2011 Trunk 0-1K 154.3db
157.??....and done.
Old 12-05-2011, 07:35 AM
mcmuffin's Avatar
0/11 sssss3380
get a universal gain knob that goes through your rca's bro
look at the pac lc-1
*** NEW BUILD COMING SOON ***
its a secret for now
Old 12-05-2011, 07:37 AM
9515ROB's Avatar
0/11 sssss2057
Just get a Pac LC1
Being loud is waste of money
880prs/Front-Hybrid Audio Technology Legatia L8 L3 L1v2 3-way/Sub- 3 blown MB Quart RLP-304 shallow mount 12s/Sub Amp- Visonik v2908/4ch- DD C4a
Still got a lot of stuff left to get
Old 12-05-2011, 09:57 AM
Regardless of what kind of cable is used, there should be two wires connected inside the knob. The knob changes voltage, so you can simply solder the connections in parallel to control both amps. That's the way my AP 1800 is at least.
bc2000 remote knob?? fyerbyrd22 (Crescendo) 1 07-22-2011 02:11 PM
Gain knob question. 2 amps 1 knob jonny101abc General Car Audio Discussion & Questions 9 07-04-2010 03:38 AM
remote knob bobbygilly (Crescendo) 4 06-13-2010 11:49 AM
Build an a/d/s/ AC502 remote bass knob remote from a different bass knob? MisterTedster General Car Audio Discussion & Questions 0 02-26-2010 10:57 PM
