Could this bee too much power for a HDC418 daily? - Car Audio Classifieds!
Old 12-05-2011, 08:00 AM
David97's Avatar
0/11 ssssss553
Question Could this bee too much power for a HDC418 daily?
So i'm going to be getting a Sundown SAZ-4500 off a buddy here in the next month or so, and I plan on using it with my single HDC4.
Gonna be building a new box for it and what not, but do you think this is too much power for a lone HDC4? I know it can take a 3500 no problem. But I'm thinking that a 4500 may be a little much. And of course the gains and stuff wont be set at full or probably anywhere near a half even.
Input greatly appreciated!
1998 Jeep Grand Cherokee, 4th Order Wall| 8 15"s | Eclipse | Sundown | Crescendo | Selenium | Audio Technix | KnuKonceptz | Second Skin | Singer | PSI | XS Power | Project dB
Old 12-05-2011, 10:07 AM
Quite Northern Michigan
0/11 sssss1309
If its not clipped, and in the right enclosure, it will take it no problem...
Remember, the pain inside can't be fixed by something outside, all you can do is cover it up that way. It's totally an inside job.
Everything in life is a test. You always come out stronger on the other side.
Old 12-05-2011, 10:12 AM
TeamOSC's Avatar
0/11 ssssss207
D1 right? I would'nt run a single D1 off that amp unless you were gonna run it @2.I've run them on big power w/no problem but not daily.
Team O.S.C.
Team XS Power
Old 12-05-2011, 10:57 AM
0/11 sssss5305
Also depends upon your idea of daily as playing full tilt at 30hz for a long time would push any sub very hard with that much power. Dial it back a little for long playing sessions and crank it up for short demo's and to meter and you should be fine...
Old 12-05-2011, 02:58 PM
sruggles1976's Avatar
0/11 ssssss271
Let it bang man. An AQ 3500 is 4300 rms, and I used one on a 15 for months daily at .5. If you have common sense you will be just fine.
Sub: AQ HDC4 15
Amp: AQ3500D.1
Electrical: Big 3, 2 runs of 1/0 Wire, Dual G31 Yellowtops
Intrepid is 2X National Champ MWSPL Basic Trunk
151.2 db @ 1880 watts clamped on the dash
Old 12-05-2011, 06:37 PM
tommytee's Avatar
0/11 ssssss515
it will handle it,plus you will be lucky if you see 3/4 of the power from the amp with box rise and voltage loss.AND THE GAIN IS NOT A VOLUME KNOB.no worries
2010 gmc sierra. Walled 4 18's 2 taramps 12k.
Team taramps, team ds18, team digital design, team Xstreamaudio.
Old 12-05-2011, 11:50 PM
David97's Avatar
0/11 ssssss553
Haha I have common sense. And I forgot that the AQ3500 does [email protected]
Thanks guys!
Old 12-06-2011, 08:35 PM
0/11 sssss1309
Uhh the saz makes quite a bit more than that...
Old 12-07-2011, 11:48 AM
0/11 ssssss271
Sweet. We have also ran that sub on a DC 7.5k at .5 ohm.
Sub: AQ HDC4 15
Amp: AQ3500D.1
Old 12-08-2011, 08:46 AM
0/11 ssssss802
Thanks guys!
The way you mention the gain settings make me think otherwise. No offense.
Which amp for daily power/reliability? markt3307 General Car Audio Discussion & Questions 18 11-22-2010 07:03 AM
most power daily!! SUBW123 General Car Audio Discussion & Questions 9 02-18-2010 09:43 PM
hey chad bee. silvercookie Off Topic Chat 1 12-04-2009 05:15 PM
New bee pocketchange New Member Orientation 6 07-15-2009 08:18 PM
