what do i set my subsonic to and how does it work?? - Car Audio Classifieds!
Old 12-05-2011, 06:58 PM
0/11 ssssss244
Default what do i set my subsonic to and how does it work??
have no idea
Old 12-05-2011, 07:07 PM
stuntside/teamsuperbass's Avatar
0/11 sssssss93
from what i heard is that its really only used with ported sub boxes so the sub will not bottom out on itself.
Old 12-05-2011, 07:10 PM
duro78's Avatar
0/11 ssssss386
10 below what ur box is tuned too
Sent from my DROIDX using Tapatalk
Head unit-cda 9887/ dsp-jbl ms8 /Amps- 2 ppi p900.4
/tweet- lpg26na /mids-tang band w3 /mid bass-dayton rs180/subs- 2 10w6v2
Old 12-05-2011, 07:11 PM
0/11 ssssss215
If you mean the subsonic filter it filters out low bass notes if you have a ported enclosure set it around 25hz/30hz depending on your box tuning. For a large to medium sealed box 20hz, a small sealed you can set it much lower or turn it off. This is just a guide line the filter protects your subs from over excursion.
0/11 ssssss244
Lol yea I knew that much
Old 12-05-2011, 07:13 PM
0/11 ssssss244
Ported tuned to 35 hz
Old 12-05-2011, 07:15 PM
0/11 ssssss215
You should be good with 25hz
Old 12-05-2011, 07:59 PM
Blackone1125's Avatar
0/11 ssssss107
For a sealed box, they're not required. The subs have a natural roll off according to their frequency response and the airspace of the chambers within the enclosure. For vented/ported boxes, setting the subsonic filter below the box's port tuned frequency increases your chances for unloading, where the subs have little to no control and things start getting very smelly. If your equipment has an accurate crossover, then you should be able to tell pretty quickly while tuning. Hope this helps.
1998 BMW 540i
Headunit: Stock DSP; Hifonics MX-1
Front Stage: Cerwin Vega 5.25's
Rear Stage: OEM 5.25's
Sub: RE Audio SX 10.4
Amps: Rockford 400.4 & bd1000
How do I set the subsonic filter? jstjst General Car Audio Discussion & Questions 7 10-01-2011 08:00 PM
What should i set my subsonic and low pass filter to ? ruffbrian General Car Audio Discussion & Questions 8 12-01-2010 11:30 PM
Subsonic Filters. 350zkid General Car Audio Discussion & Questions 18 06-13-2009 04:56 PM
Would this set-up work? Bologna General Car Audio Discussion & Questions 95 04-30-2009 08:54 PM
subsonic q Snwbrdr1 General Car Audio Discussion & Questions 6 04-17-2009 02:50 AM
