anyone know the power eff. on this amp? - Car Audio Classifieds!
Old 12-06-2011, 12:42 PM
0/11 ssssss269
Default anyone know the power eff. on this amp?
SS RUB 2500
i talked to tech support and they said they dont rate them. (he was a load of help with my other questions also)
and i have looked for a few mins on the web to see if anyone had a clue, and i couldnt find anything reliable.
im trying to figure out all my power voltage/amps factors and needs for this amp.
i have heard it was all the way up to 86% @ 1ohm
i have heard it was as much as 80% @ 4ohms
Old 12-06-2011, 12:43 PM
0/11 ssssss269
sorry, i didnt specify.
LOOKING FOR POWER EFFICANCY %
Old 12-06-2011, 02:32 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
What does it matter The reason they don't do it is eff. varies to much from application to application that its almost impossible.
No one goes on eff. ratings. Its just understood that class a or a/b are less eff. then class d. Which is usually around 65-75%.
Only thing you should worry about is if the amp does rated power....
Its funny you ask this, but in another thread you want to run it at .5 ohm.
Old 12-06-2011, 03:33 PM
0/11 ssssss269
Umm, okay, I wanted to know because I wanted to know the current draw of this amp. I wanted to make sure I'm feeding it enough power to prevent clipping.
Old 12-06-2011, 04:03 PM
Ja Marcus
0/11 sssss6975
I think you are a bit confused as to what your wanting.
Input signal is what clips the amp.
Old 12-06-2011, 04:07 PM
0/11 ssssss269
i was told low voltage can cause clipping. but i still want to know the power eff. so i know the current draw.
Old 12-06-2011, 04:10 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
Relax.. it was a simple question.
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 12-06-2011, 04:24 PM
groundpound4200's Avatar
Errday I'm Hustlin'
0/11 sssss1785
I think most Class D amps claim around 86% efficiency at 4 ohms for those that do actually list a spec. It's only downhill from there and where most people run them I'd agree with the 65-75%
2007 Honda Pilot
Sundown SAZ 1500D V.3
2 Atomic APX 818 10"s
Taylor Lampart aka NewAgeKing
0/11 ssss31256
Suffice it to say if you can supply it with the amperage the fusing is rated at, you will be fine.
Low voltage does not cause clipping. Over-driving the amplification circuit causes clipping. {asking it to do more than it can with the given input signal & Or with less than it needs}
Low voltage can cause power supply transistors to blow up because they overheat due to the excessive amperage needed to make up for the lack of voltage.
audioarsonal (12-06-2011)
Old 12-06-2011, 04:37 PM
worstenemy453's Avatar
Veteran Member
0/11 sssss4401
Low input voltage causes clipping. [RCA voltage]
In short, if you are worried about clipping, get a line driver. Hifonics MX-3 is one of the most amazing audio pieces, ive ever used.
2005 Toyota Tundra Double Cab
Sub: ---
Speaks: ---
Headunit: ---
Street Stars Motorsports - All Thing Performance/Custom.
FS: 3 XS Power D1600's & XS Power 16V Charger $LICK CALIFA$ Wiring, Electrical & Other Installation Equipment 41 11-24-2011 08:29 PM
WTB: Good 4ga/8ga Power & Ground & more extreme Wanting to Buy (WTB) 2 01-24-2011 10:10 PM
WWT: Cadence ZRS 12, Orion 6001 amp, and Power Acoustik 1800 amp. boboridesbmx Car Audio Trader (WTT) 1 06-11-2010 06:30 PM
