AQ 4-channel gone? - Car Audio Classifieds!
Old 12-06-2011, 03:00 PM
alonzoub's Avatar
0/11 ssssss102
Default AQ 4-channel gone?
What happened to the AQ 4x90? I was thinking about getting one of these but it seems to have disappeared from the website. Are they still being produced?
'05 Mazda 3 | Big 3 1/0 Knu CCA | JVC Arsenal KD A615 | Image Dynamics Q1200.1 | Eclipse EA4200 | 1/0 Knu CCA | Rainbow SLC 230.25 NG Comps | CDT CL-5E mids | (2) Image Dynamics IDQ10v3 D2 | Custom ported box, 3.2 cu.ft 30Hz
Old 12-06-2011, 03:05 PM
0/11 ssssss647
Feedback Score: 21 reviews
they are making a newer 4 channel thats why
The Following User Says Thank You to bread0710 For This Useful Post:
alonzoub (12-06-2011)
Old 12-06-2011, 03:30 PM
alonzoub's Avatar
0/11 ssssss102
Ah, thanks for the quick response.
Old 12-06-2011, 03:47 PM
0/11 ssssss337
We listen to customer feedback.
The AQ4x90 is being replaced by the new AQ4x120. We are also bringing out the new AQ2x220. .The new amps are scheduled for Jan.
The new AQ comp sets are on the way along with the AQ6x9 four ways and the new AQ6.5 three ways all at VERY affordable prices.
We have had many requests to bring back the AQ20. This is a very expensive amp to produce but if enough interest is shown we will do another production.
The Following User Says Thank You to Audioque For This Useful Post:
Eazye420 (12-07-2011)
Old 12-06-2011, 03:50 PM
0/11 ssssss647
whats the the specs on the AQ4X120 and the AQ2x220?
Old 12-06-2011, 08:35 PM
Quite Northern Michigan
0/11 sssss1309
I might be down for a 20k. Same as the old one?
Remember, the pain inside can't be fixed by something outside, all you can do is cover it up that way. It's totally an inside job.
Everything in life is a test. You always come out stronger on the other side.
Old 12-07-2011, 03:13 AM
0/11 ssssss802
Most likely the same as the previous one. As an owner of 3 of the AQ20ks....such KILLER amps. Clamped almost 11,980 watts from one at 14.1v calculated ohm load 1.24ohms.
Old 12-07-2011, 09:22 AM
0/11 ssssss337
The same but with the latest goodies on it.
Old 12-07-2011, 12:34 PM
tommytee's Avatar
0/11 ssssss515
2 aq20's would work on my new set up for this year.was trying to stay in 2000 to 4000 modified,but this year going to street beat 3 set up with 6 aq hdc3-a 18's in a new wall.if you do another run of them put me down for 2.
2010 gmc sierra. Walled 4 18's 2 taramps 12k.
Team taramps, team ds18, team digital design, team Xstreamaudio.
Old 12-07-2011, 12:45 PM
AMI CUSTOMS's Avatar
SOUNDQUBED EXPERT
0/11 ssssss524
You can't run that much cone area in sb3, that would be a sb4 setup or if you go higher voltage sb5.
3x STREETBEAT World Record Holder
-Streetbeat 4 - 161.9 db
-Streetbeat 5 - 162.6 db
The Black Nasty (SOUNDQUBED)- 160+ db
Old School Sony ES 1 ohm per channel 4 channel amp TKCARAUDIO Multi-channel Amplifiers 0 05-15-2011 10:53 PM
will running a 4 channel amp in 4 channel mode sound better than 2 channels? MERQUE General Car Audio Discussion & Questions 5 02-09-2011 09:16 AM
RCA 4 channel & 2 channel pairs NEEDED jason4532 Wanting to Buy (WTB) 3 12-06-2010 09:28 PM
wtb: american bass 4 channel or 2 channel amp blkmrideon22s Wanting to Buy (WTB) 0 02-17-2010 02:50 PM
WTT: Swiss Audio 2-Channel for powerful 4 Channel twistedchild420 Car Audio Trader (WTT) 6 02-15-2010 09:39 AM
