Brand New Kinetik Battery sitting low on voltage - Car Audio Classifieds!
Old 12-06-2011, 11:53 PM
adio25's Avatar
0/11 ssssss100
Default Brand New Kinetik Battery sitting low on voltage
Just got a new kinetik red series equivalent to the HC1800 from sonicelectronix today. Tested the voltage and its sitting at a measly 12.05v. Is that something to worry about or would a trickle charge bring it right back to its normal 12.9v resting voltage?
Head Unit - Alpine CDE-123
Front Speaks - Sundown NeoPro V2 6.5"
Sub Amp - Audioque 3500.1D
Sub - Audioque HDC3 15" D2 - 4.5 cubes @ 38hz
Refs- lightningbolt44, andar, dbeez, robertspangler, dextermoped, johnjv29, blazin33, titan808, hispls
Old 12-06-2011, 11:58 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
if its new id try to give it a charge as they typically arent fully charged from the factory
-Youtube Channel
Old 12-07-2011, 12:00 AM
0/11 ssssss855
It shouldn't be too far off to top off with a trickle charger might have been on the shelf for a while It's always a good idea to charge any new battery before adding it to.your system if after you charge it still has low voltage then call them up I'm sure they will switch the battery out for you
Sent from my PG86100 using Tapatalk
Old 12-07-2011, 11:15 PM
0/11 ssssss183
just needs a charge
Old 12-09-2011, 01:39 AM
adio25's Avatar
0/11 ssssss100
This is what I got from customer service,
"We apologize but please understand that these batteries do sit for some
time at the manufacturers location then ours until sold. Although the
item is know where near its expire date it can lose some voltage from
sitting, you can put the unit on a charger for a couple of hours if you
want those extra points."
Old 12-09-2011, 05:52 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
That sounds about right. Once manufactured and sold kinetik has no control on how they are handled.
That's why its always suggested to charge any new battery.
Low Resting Voltage on used Kinetik kern417 General Car Audio Discussion & Questions 7 01-16-2012 07:07 AM
low voltage basswagon General Car Audio Discussion & Questions 10 06-02-2011 09:09 PM
Low charging voltage jt_buck General Car Audio Discussion & Questions 9 05-28-2011 07:27 AM
Low voltage? splvictim20 General Car Audio Discussion & Questions 26 10-02-2009 11:56 PM
