Whats your thoughts? Safe? - Car Audio Classifieds!
Old 12-08-2011, 08:29 AM
Awaiting Confirmation
0/11 sssssss72
Default Whats your thoughts? Safe?
I am about to buy some speakers and I have the following wiring option either a .67ohm load or a 1.34ohm load. My amp is a DB Drive A7 2000.1 and is rated at [email protected] Would it be best for me to go with the option to wire amp @1.34ohm or will wiring the amp at .67 be ok? I would think .67 would be fine as with box rise and all I will be well above a 1ohm load. What do yall think? I would like to get as much out of the amp as possible but I want to do it safely. I have that electrical to support the amp 180amp alt and 1 group 31 as well as the starter battery.
Old 12-08-2011, 09:08 AM
0/11 sssssss72
hmmm I wonder
Old 12-08-2011, 09:17 AM
I run my Audiopipe 1800 at .67ohm on the stock alt (90amp) and regular underhood battery w/ the big 3. It's fine, even when my voltage drops into the 10s, lol. I would say go for it.
Old 12-08-2011, 03:32 PM
Quite Northern Michigan
0/11 sssss1309
Facepalm.... As long as you have the electrical, you can run pretty much any impeadence you please.
Remember, the pain inside can't be fixed by something outside, all you can do is cover it up that way. It's totally an inside job.
Everything in life is a test. You always come out stronger on the other side.
be safe davidrforbus Georgia SPL 15 04-16-2011 08:21 PM
Would it be safe too... Audio_Prodigy General Car Audio Discussion & Questions 5 09-18-2010 10:37 PM
Is there a safe way? davidrforbus General Car Audio Discussion & Questions 6 09-18-2010 04:49 PM
is there any safe way to.... newarkbeast973 General Car Audio Discussion & Questions 18 07-17-2010 09:50 PM
