Mounting Amp on box... safe? - Car Audio Classifieds!
Old 12-08-2011, 04:33 PM
gti1.8t's Avatar
0/11 ssssss361
Default Mounting Amp on box... safe?
Hey all!
This year its going to be very tight for space... I was wondering if its safe to mount my amp on my sub box? The wood I'll be using is 3/4" Birch (hopefully 9+ plies) resined on the inside, 45's & bracing.
Is there anything I can put between the amp & box to help if there is vibrations? Any recommendations?
Cheers!
Old 12-08-2011, 04:35 PM
massivespl's Avatar
0/11 sssss8409
its not the safest but it can be done.... i would use rubber spaces between the box and amp..
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 12-08-2011, 04:37 PM
gti1.8t's Avatar
0/11 ssssss361
ahh gotcha, i'll be bolting up so ribber on all 4 bolts will probably help... I just dont have anywhere else to put the amp sadly...
Old 12-08-2011, 04:39 PM
0/11 ssssss288
I've done it with 0 negative side effects I always mount the amp to a piece of scrap wood, put a layer of deadener on the other side of that board anda piece of deadener on the box where it'll be mounted. I'm pretty sure most those steps aren't needed but make me feel better.
Need box help? Pm surreal
Old 12-08-2011, 04:42 PM
tacomaguy1's Avatar
0/11 sssss4401
I'd never mount an amp directly onto the box itself...I do like this guy. Mount the amp on a piece of 1/2" or 3/4" mdf then mount that to the box with deadener on the side of the wood that's hitting the box
so it...box-deadener-wood-amp
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 12-08-2011, 04:45 PM
groundpound4200's Avatar
Errday I'm Hustlin'
0/11 sssss1785
I have a pair of amps on my box. I doubled up the wood where the amps are mounted.
There was nowhere else to mount them... so far so good. Rubber bushings will help kill some vibration as well
2007 Honda Pilot
Sundown SAZ 1500D V.3
2 Atomic APX 818 10"s
Taylor Lampart aka NewAgeKing
Old 12-08-2011, 04:46 PM
gti1.8t's Avatar
0/11 ssssss361
ahh makes sense... Fingers crossed that all this will fit!! lol
I was thinking of putting dynamat on the amp itself but I'm thinking that might just heaksoak the amp which isnt a great idea... I think I'll give that a try..
wood - deadener - wood - amp
Box building & subwoofer mounting hardware doug118 Enclosure Discussion & Design Construction Help 4 05-25-2011 11:26 AM
Amp wiring (safe?) JLAUDIO Bo1 901 General Car Audio Discussion & Questions 9 02-05-2011 06:47 PM
WTB Jbl amp mounting feet & bass knob dman1049 Wanting to Buy (WTB) 1 01-11-2011 12:55 AM
Mounting amp on box: good or Bad Idea? jfoodstamp General Car Audio Discussion & Questions 23 12-12-2010 02:10 PM
Mounting Amp rack to box, how to reduce/remove vibration W O T General Car Audio Discussion & Questions 8 10-01-2009 05:12 AM
