is my alt bad or is it my battery? - Car Audio Classifieds!
Old 12-08-2011, 07:34 PM
MERQUE's Avatar
0/11 ssssss622
Default is my alt bad or is it my battery?
when cold my stock battery sits at 12.02 volts. when cold it will charge up to 14.4 with my stock alt(i dont have my HO alt installed). once the car warms up the voltage at idle will drop to 13.8 and with lights on and radio low it will sit at 13.6. while driving the car the voltage will stay at 13.8.
is this a bad battery or alt? the battery sticker is dated 09/08.
Old 12-08-2011, 07:37 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
battery just has a low resting voltage. try charging it with a trickle charger and see if it helps. as an idea, most good AGM batts rest in the high 12's
-Youtube Channel
Old 12-08-2011, 07:40 PM
0/11 ssssss459
Is that 12.02 with the car off and no lights or anything like that on? I would think it is the battery.
You should see higher than that with no key in the ignition and nothing on, and I have a small drop when I go to turn on my headlights and things in the car. You should test and see if it drops significantly with the car off and accessories on.
Old 12-08-2011, 07:43 PM
yessam430's Avatar
Stop Reading This!!
0/11 ssssss258
Battery it seems i just had to swich out my battery, but the voltage was wayyyy lower than that
Sent from my PG06100 using Tapatalk
Brought From: jjffy6
Traded With: Dmxand1
EBAY account: DanaMassey430
Old 12-08-2011, 07:45 PM
MERQUE's Avatar
0/11 ssssss622
yes with nothing on and no key in it sits at 12.02.
i plan on getting a couple deka 9a31s soon, what kind of battery would accent it the best? a deka wont fit under my hood otherwise i woulde use that.
Old 12-08-2011, 07:49 PM
Active Member
0/11 ssssss846
Feedback Score: 23 reviews
Charge the battery overnight, with a charger, chances are you are using your system full tilt and your stock alt cannot support the load so it drains the battery. So your battery is prob sitting at 50% charged.
Old 12-08-2011, 07:55 PM
MERQUE's Avatar
0/11 ssssss622
the thing is i dont have a system in right now. all i had was a 4 channel. its the stock alt. its 115 max and 60 idle. i also have big three in 0 gauge.
Bad alt or belt? Jolly Green Giant General Car Audio Discussion & Questions 10 01-08-2011 01:57 PM
replacing a bad cell in a battery? nervewrecker General Car Audio Discussion & Questions 3 01-02-2011 06:44 PM
getting bad headlight dimming, need ideas for 2nd battery! papito General Car Audio Discussion & Questions 38 08-11-2010 02:00 PM
good or bad idea to use this battery arntsmag General Car Audio Discussion & Questions 1 07-21-2010 10:02 PM
My alt is bad obrien202 General Car Audio Discussion & Questions 68 10-01-2009 09:47 PM
