rf power 800a4 question - Car Audio Classifieds!
Old 12-08-2011, 10:26 PM
logan23afroman's Avatar
0/11 sssss1813
Feedback Score: 30 reviews
Exclamation rf power 800a4 question
i just recently got a trade for a rockford fosgate power 800a4 4 channel amp, its in great shape, but i went to test it for power up and a quick run, but im having a problem, it has two 8 gauge powers and two 8 gauge ground terminals, i am only using one power and one ground...what i have to power it is a pc power supply, it was just testing a jl 300/4 so its not that, after i connected the power and ground, i used a dmm to test voltage, i was at 12volts....is that to low for this amp? anyways it reads normal, but after i power the supply off and connect the remote wire, it wont even turn the fan on the power supply and the volts are at 0...is there a short some where? i connect it to my jl and it works fine!! please help me!!!
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
Old 12-09-2011, 12:45 PM
0/11 sssss1813
any body have a clue??
4xSundown sa-8''s
Old 12-09-2011, 03:28 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
Only thing you can do is wire it up properly, using both power and grounds and see if it fictions the way it should. If not, then you have a bad amp.
Sent from my EVO 3D using Tapatalk
Old 12-09-2011, 03:38 PM
usampsman's Avatar
Awaiting Confirmation
0/11 sssss1742
Its bad. I test on a pyramid 52 amp power supply... I had a few amps that drop voltage 2 0 and pull have no amp draw
Changes are if u hook it up in a car it will smoke! Just had a diamond audio d7 6ch do this so deccided to try in car hopeing it just didnt like the power supply and it errupted.... lol nothing like smoking a 450 dollar ebay amp
TEAMHEAVYHITTERZ... CURRENT BUILD IS FOR YOU LOCAL HATERS
Old 12-09-2011, 03:40 PM
usampsman's Avatar
0/11 sssss1742
also on your rf amp the power/ground inputs are one piece internally so u only need one connected
Old 12-09-2011, 03:43 PM
0/11 sssss1813
I figured they were all one piece, but why does the remote make it short my amp out?? It reads 12v till I connect the remote wire..
4xSundown sa-8''s
Old 12-09-2011, 03:54 PM
usampsman's Avatar
0/11 sssss1742
An amp with just 12v hooked to it isnt really trying to do anything...., when remote is hooked up it turns the amp on
Old 12-09-2011, 04:17 PM
Nik592's Avatar
0/11 sssss2000
I'd like to let everyone know as well on my behalf that Logan got this amp from me, but I'm working with him and were gonna either Get this thing fixed or compensate him
don't want a bad name so thought id post up
"Insert witty signature here"
Old 12-09-2011, 04:48 PM
0/11 sssss1813
I know that lol, but why would hooking up the remote shut off my power?
4xSundown sa-8''s
Old 12-09-2011, 04:54 PM
0/11 sssssss71
And Nik592 got the amp from me lol... It was working fine last time I had it plugged in but I upgraded to a t8004... I will make sure it gets fixed or refund for the amp
power wire question stevenminix General Car Audio Discussion & Questions 5 02-28-2011 11:09 AM
Question about Precision Power PPI Mosfet Power Series "M" Amps vipnite General Car Audio Discussion & Questions 1 01-30-2011 02:44 PM
Power Question(s) PhishHead General Car Audio Discussion & Questions 3 08-26-2010 11:31 AM
OZ power series question Jacobbz206 Enclosure Discussion & Design Construction Help 6 12-20-2009 10:50 PM
FS: RF 800a4 - 4 channel Amplifier upzaw2000 Multi-channel Amplifiers 3 01-25-2009 11:36 AM
