how to wire up a AQ 2200 - Car Audio Classifieds!
Old 12-08-2011, 11:45 PM
0/11 ssssssss7
Default how to wire up a AQ 2200
Need help on wiring up a2200 to two HDC3 12 D1
WILL IT PUT OUT A 1000 WATTS TP EACH SPEAKER
Old 12-09-2011, 12:20 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Are you planing on running those subs in series to get a 1 ohm load? I hope.
And yes, the subs will split the output so roughly 1k each.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 12-09-2011, 12:22 AM
0/11 ssssssss7
Yea 1ohm load
Old 12-09-2011, 01:50 AM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
Subwoofer Wiring Diagrams
Team AST-2 15" Everest Sound Labs Bdx.Powered by Flatline audio ba2
Team Psychoacoustics-11" Adjustable Psycho Port. 12 T3 Audio 6x9s for mids
Old 01-08-2012, 09:33 AM
0/11 ssssssss8
I tried it that way with mine, now I am taking them back out of the box to wire the coils parallel and the subs in series. I had barely any output like that.
Old 01-08-2012, 12:49 PM
alonzoub's Avatar
0/11 ssssss102
Coils in series and Subs in parallel will yield the exact same output as Coils in parallel and subs in series. Unless you wired them incorrectly to begin with.
Did you set the gain correctly?
'05 Mazda 3 | Big 3 1/0 Knu CCA | JVC Arsenal KD A615 | Image Dynamics Q1200.1 | Eclipse EA4200 | 1/0 Knu CCA | Rainbow SLC 230.25 NG Comps | CDT CL-5E mids | (2) Image Dynamics IDQ10v3 D2 | Custom ported box, 3.2 cu.ft 30Hz
Old 01-08-2012, 06:23 PM
0/11 ssssssss8
I have Pos in from amp, neg to pos from coil to coil, and neg back out on both subs. hu has 4v outputs, gain @ about 1/4 which would match the 4v. dual 1 ohm coils, ~1ohm load. subsonic @ ~35, lpf @ ~100. subs barely move, i can just feel vibration. doubt subs wired wrong, I have been installing for 13yrs, and I double checked. I think my ring terminalsfor power and ground are $#!T, getting new tomorrow.
Old 01-09-2012, 07:13 PM
0/11 ssssssss8
All new power and ground terminals. Big 3, kinetik in back, and 180 amp alt. 14.3 volts, still crap for output. premier hu, sub on and @ 0 (-6 to +6) amp set like directions state. new rca's. any ideas?
Old 01-09-2012, 07:18 PM
duff_thrust's Avatar
0/11 ssssss629
how have you set your gains. What is your subsonic set at? What is your HPF set at? Bass Boost, etc.
Old 01-09-2012, 07:21 PM
0/11 ssssss629
I've used a DD-1 to set my 2 2200d's that I have strapped. My gains are much higher than I assumed they should be. HPF should be around 80 as a start atleast. Subsonic (I don't use it), Bass boost off. Basically if you want a general idea of where your gain can be set.
If you know how to figure it. It's very simple to get a general idea with a dmm where you're setting your gains at your nominal before rise etc.
The Following User Says Thank You to duff_thrust For This Useful Post:
woofer cooker (01-09-2012)
How to wire up 2200 4x90 underdogg General Car Audio Discussion & Questions 8 11-24-2011 04:50 PM
Aq 2200 mhenich123 Wanting to Buy (WTB) 1 10-24-2011 04:49 PM
2x AQ 2200 TheJesus Mono Amplifiers 26 08-21-2011 11:56 PM
RD 2200 v.2 AudioFreak General Car Audio Discussion & Questions 135 09-20-2010 09:50 AM
aq 2200 kingmade08 General Car Audio Discussion & Questions 8 03-01-2010 10:57 PM
