how much power can i run with a 240 amp alt? - Car Audio Classifieds!
Old 12-09-2011, 10:21 AM
MERQUE's Avatar
0/11 ssssss622
Default how much power can i run with a 240 amp alt?
you guys think with a 240 amp alt and 2-3 deka 9a31s+ stock battery i could run 6500 rms?
Old 12-09-2011, 10:26 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
thats probably on the upper limit. but then again im VERY conservative with voltage. 12's scare me.lol. id say 5k is doable pretty good with 3. as long as you charge the batteries every now and then
-Youtube Channel
Old 12-09-2011, 10:30 AM
JMoney18's Avatar
0/11 sssss1577
That's a lot of power.... do a few runs of 0 gauge and i'd get like 4 of the 9a31's, can't have to much overkill on electrical. If your on a budget, do 2-3 now and turn the gain down if your voltage drops, add batteries when you get more money. Just my .02
Old 12-09-2011, 10:32 AM
MERQUE's Avatar
0/11 ssssss622
i have an ap30001d on the way with a hdc318, but i plan on getting another audiopipe and doing 2 hdc315s instead of one 18. the untimate goal is 4 total runs of 0 gauge
Old 12-09-2011, 10:34 AM
0/11 ssssss283
another battery or 2.. a few runs of 0 gauge and ur fine
im with taylorpro.. i NEVER EVER let my amps see below 12.8 13v
Old 12-09-2011, 11:31 AM
0/11 ssssss290
i've ran my SD8000.1 off a stock battery lol, and one run of 4/0 gauge to the back on music and been fine in spurts. 300amp alt though. lots of voltage drop, but the amp is fine down to 9v and produces power that low. if you play your music full tilt for minutes at a time then you probably need 2 or 3 batteries, if running tones 4 is probably fine.
everyone on here is going to disagree with me though most likely. lots of electrical overkill on this forum, which is a good thing lol, but you can skimp by with less. especially if not metering, the difference between 5k and 6k isn't too noticeable so just turn the gain down slightly
Old 12-09-2011, 11:48 AM
MERQUE's Avatar
0/11 ssssss622
i dont do tones, all music
Old 12-09-2011, 03:15 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
my only suggestion is if there is doubt, dont try it. and if you do, if there is a lot of voltage drop, stop trying it.lol
-Youtube Channel
Old 12-09-2011, 03:31 PM
0/11 ssssss139
You supposed to charge batteries even if you don't use em with the car off?
Old 12-09-2011, 03:37 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
hell yeah. alternators charge the batteries but not like a nice slow trickle charge can. i charge my AGM's once a week if i can. never hurts to take care of them a little more then need be. just makes them last longer and perform better
-Youtube Channel
The Following User Says Thank You to taylorpro For This Useful Post:
Dr. Slam (12-09-2011)
nissan altima dc power 275amp alt and c&d battery. poconos pa. kickerfanatic Craigslist Deals 0 08-02-2011 03:54 PM
optimus and mtx 240 amp values Bushj311 General Car Audio Discussion & Questions 2 04-19-2011 07:13 PM
240 amp MechMan GM alternators (3 available) MECHMAN Wiring, Electrical & Other Installation Equipment 30 08-29-2010 07:31 PM
AP AP30001D - worth the cash?? run low imp? wanna run a D1 sub to each amp.... W O T General Car Audio Discussion & Questions 0 10-18-2009 07:27 PM
power master 200 amp alt keifersracing Wiring, Electrical & Other Installation Equipment 14 12-15-2008 02:04 PM
