are extra batteries equivalent to a second alternator? - Car Audio Classifieds!
Old 12-10-2011, 09:15 PM
MERQUE's Avatar
0/11 ssssss622
Default are extra batteries equivalent to a second alternator?
i just found out powermaster makes a dual alternator bracket for my car that will bolt right up with my old stock alt. i currently have a 240 amp irragi alt and my other stock one is 115 amps.
i want to run a total of 6400 rms. i plan on running two 3k monoblocks and a 400 watt 2 channel amp. if i buy the bracket i will have a total of 355 amps available with my irragi and stock one. i can also buy a stock 200 amp alt thats pretty cheap, its about $130 so that will give me 440 amps if i go that route.
would it be better to just use the irragi 240 and instead of spending money on the dual alt bracket get some batteries? will an extra 2 deka 9a31s be equivalent to a another 115 or 200 amp alternator?
if i buy the bracket could i get away with just another small battery in the trunk or upgrading my stock battery up front to a deka 9a31?
Old 12-10-2011, 09:23 PM
usampsman's Avatar
Awaiting Confirmation
0/11 sssss1742
If u dont buy matching alts its pointless... If alts arnt identical and hooked up together they fight each other and the less powered one wins.... Its more in depth than how i explainned but thats the easy way of explaining it
TEAMHEAVYHITTERZ... CURRENT BUILD IS FOR YOU LOCAL HATERS
Old 12-10-2011, 09:26 PM
0/11 sssss1330
Use the stock alt to power the vehicle and it's accessories and use the HO alt for the system
2010 Volkswagen CC
HRE Wheels | Nitto Tires | Solo-Werks
Ground Zero | Ampere Audio | Juicebox Battery | AudioControl | KnuKonceptz
Old 12-10-2011, 09:40 PM
0/11 sssssss89
this. you may be able to run your stock alt on not only its accessories but also the 400 watt 2 channel and run the monos off the second alt but make sure to watch the voltage because obviously the lights wouldn't dim and any other obvious red flags could be overlooked when doing this.
Old 12-10-2011, 10:24 PM
MERQUE's Avatar
0/11 ssssss622
im not really trying to have two different electrical systems, too much work. so there is no way what so ever to have the two alts work together? i thought you could just jump the wire on the pcm harness with the other one and they would work together?
Old 12-10-2011, 10:26 PM
Me > Lord Van
0/11 sssss2831
Huh?
I would like some proof of this please.
There are TONS of people who run multiple alts of varying sizes.
Team DOA
10 inches of terror
One DD 9510F + one kicker zx2500=150+ db
One Sundown SA-8 + 2 mb quart 2000's = 150+ db
-2006, 2007, 2009, and 2010 MECA World Champion
-2008 Bassrace 130-139.9 National Champion
Old 12-10-2011, 10:27 PM
0/11 sssss3986
clueless motherfukers
The Following 2 Users Say Thank You to 2000LaDe For This Useful Post:
David97 (12-11-2011), Infinitelybaffled (12-10-2011)
Old 12-10-2011, 10:29 PM
MERQUE's Avatar
0/11 ssssss622
lol will it work?
Old 12-10-2011, 10:30 PM
Me > Lord Van
0/11 sssss2831
Originally Posted by MERQUE View Post
lol will it work?
Yes it will.
You can ask the dozens upon dozens of people who have already done it.
Team DOA
10 inches of terror
Old 12-10-2011, 10:34 PM
MERQUE's Avatar
0/11 ssssss622
Originally Posted by tommyk90 View Post
Yes it will.
so was i right about just jumping the pcm harness of my stock one to my irragi?
When adding extra batteries thebutcher General Car Audio Discussion & Questions 13 03-25-2013 09:33 PM
getting a new car so alternator will have to wait how would an extra power cell do? jaeguerra909 General Car Audio Discussion & Questions 26 11-03-2011 12:21 AM
alternator or batteries hdman87 General Car Audio Discussion & Questions 4 11-20-2010 09:01 PM
[SOLD] Two Kinetik HC600 equivalent batteries Jolly Green Giant Wiring, Electrical & Other Installation Equipment 27 09-18-2010 08:34 PM
Extra Batteries resko1 General Car Audio Discussion & Questions 5 01-05-2010 01:21 PM
