Mounting Amp Upside Down? - Car Audio Classifieds!
Old 12-10-2011, 11:24 PM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
Default Mounting Amp Upside Down?
I'm planning on doing a false floor in my Forester and was wondering if there would be any issues if I were to flush mount my Onyx 1500.1 upside down to the false floor with some lexan to replace the bottom plate...
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
MB Quart Onyx 1500.1
/Surreal
Old 12-10-2011, 11:29 PM
0/11 sssss3842
I wouldn't...the heatsink would be pointless and I wouldn't mount a amp inside a falsefloor unless u have great ventilation...
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 12-10-2011, 11:47 PM
Dubstep Addict
0/11 sssss1802
I would install several fans for ventilation under the false floor.
Aren't the mosfets the main components that are cooled by the heatsink? They are cooled by the side of the amp do I don't think it would make too much of a difference. Or are the mosfets not the only thing that needs ample cooling?
File Type: jpg ImageUploadedByTapatalk1323582304.200175.jpg (156.7 KB, 12 views)
/Surreal
Old 12-11-2011, 12:16 AM
Dubstep Addict
0/11 sssss1802
Picture of the mosfets...
File Type: jpg ImageUploadedByTapatalk1323584142.540894.jpg (84.0 KB, 23 views)
/Surreal
Old 12-11-2011, 12:37 AM
0/11 ssssss855
I would think they would be ok i have my planet audio amp right side up in the Spain tire well and it gets warm to the touch but never hot with no fans circulation about 1500 rms give or take a few watts soon to be 2 k when my alt comes in you should be fine just put some fans that hit the heat sink never did get why most if not all amps are upside down ?
Sent from my PG86100 using Tapatalk
Old 12-11-2011, 12:58 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
I've seen this discussed several times and the general consensus is that it's ok to do with newer amps. Something about the way newer amp's boards or fets are attached compared to the way they used to be? I'd use some ventilation fans though.
I've only tried it with my old school amp and it was not happy upside down.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 12-11-2011, 01:06 AM
Dubstep Addict
0/11 sssss1802
I tried to search but the search using Tapatalk blows. I guess I'll end up mounting it upside down and seeing how it does and go from there.
/Surreal
Old 12-11-2011, 02:07 AM
ghostmechanic's Avatar
0/11 sssss1193
Feedback Score: 36 reviews
Yep you're right. Most of the newer amps not only run cooler but also have the "FETs" mounted vertically to the side of the heatsink like that 1 in the picture which would dissipate heat mounted either direction. The problem with older amps was the transistors were mounted horizontally to the heatsink & when mounted upside down the heat went back inside the amp instead of away from it. Plus they just run hotter in the first place.
Some newer amps like MA's & Autoteks with the stainless steel cover are designed in such a way that they're pretty much already upside down & I'd think they'd do better if you mounted them opposite or actually upside down.
I'd think you'll be fine but I do agree with others that you should try to use some fans just encase.
Tapatalk just sucks lol
u need a flux capacitor to do that bro
i swear i thought you guys were serious until i googled flux capacitor
Mounting amp upside down??? oxsign General Car Audio Discussion & Questions 4 11-12-2011 01:10 AM
mounting an amp? stevenminix General Car Audio Discussion & Questions 3 03-01-2011 09:45 PM
WTB Jbl amp mounting feet & bass knob dman1049 Wanting to Buy (WTB) 1 01-11-2011 12:55 AM
Mounting Amps upside down TahoeJoe Enclosure Discussion & Design Construction Help 14 04-03-2010 01:28 AM
Amp mounting sheldonfromltown General Car Audio Discussion & Questions 1 03-05-2010 09:24 PM
